Mr scratch....what would be a good motherboard match for E4600? I'm building one as well but I really don't know what to go for when it comes to m/b. I don't need anything over the top just a regular good value one.........and by good value I don't mean cheap.
Post a list of the other components that you're going to use to make this machine, I can give you a better answer that way.
Edited by Scratch
  • Replies 60
Funny why people keep saying Vista is shit.........i've been using it for close to a year now, not once did it ever crash. The hibernate function is wonderful. All that run on 1 gig of ram.
How did you get it to run smoothly with only a gig? Did you turn aero off?
For me, I see vista is more usless (therefore making it appear "shit" to me) coz as far as I'm concerned It doesn't have any new "essential" features that I need. XP had the nice feature of having the image previews thing for pictures compared to 98 where you had to open each jpg to look at the pic.
Only thing that would make me (more like force me to upgrade) would be DX10. But considering that games that you could run in DX10 mode (ie Crysis in Ultra high details) would kill even a 8800Ultra, I just don't see any point in getting it for the time being.
And to lingeringsoul:
Gigabyte p35 DS3L is a pretty decent entry level motherboard, it still retains the good over clocking ability of the higher end Gigabyte models.
Btw the new 512Mb 8800GT & GTS are faster than the old 640mb GTS in almost all games (Google the test charts), since they use the new core (G92) and the increase in shader processors (112 for GT & 128 for GTS compared to 96 for the old GTS).
Edited by Mayuri Krab
You can enable Ultra High settings in Crysis in DX9 on XP through an entry in the config file. Google it.
They are cheaper too, but they were not available when I bought my card... which is why I said you can get better and cheaper now, heck the q6600 has dropped by 10 bucks too. The point is - no matter what you buy it gets outdated, fast. Buy whatever suits your needs and make peace with it.
Final nail in the coffin for vista :down: ...
until they ditch xp support in games, atleast shouldn't happen for a while :rofl:
& for the video card thing, sorry, didn't read your post properly, thought you were recommending him a 640mb GTS (didn't read the top line where you said it was your rig).
I'm going for about 2 gigs of ram (maybe 4), getting 8800gt 500gb hd, don't need a super super fast cpu and mobo, just a one thats not too bad. Used for playing odd new games here and there but mostly I'll be using it to watch a lot of movies.
So yeah, can't decide whats a decent cpu speed and mobo
I read that the P5N-E SLi seems pretty good but then I dont know what is a good match.
I'd rethink your CPU and get a faster one, the 2.4 ghz e4600 will only slow down your video card. The new 45nm intel CPU's are out and some of them are cheaper and offer higher FSB support (1333 vs 800) than the older ones (use less power so they run cooler). An example:
E6850 core duo (3ghz 2x2mb cache) = $329
E8400 core duo 45nm (3ghz 2x3mb cache) = $279 <- i would looking at this cpu
(Prices ref: www.ple.com.au)
The p5ne-sli is a very good sli board, but uses an Nvidia 650i chipset (i think, dont have time to google) which doesnt support 45nm CPUs. Basically If you're planning on getting another video card now or in the next month or two and want to get the E4000 series intel CPUs, its worthy to consider this board.
if you're in this scenario however:
- you're not planning on SLI
- want the newer 45nm cpus
- dont want to tinker around and overclocking your pc that much
get an intel chipset. The nvidia chipsets are catered for the enthusiasts, good tweakability but also prone to weird driver problems/constant updates and then problems from those updates. Anyone who's had these chipsets and know what they are doing, have had a beta/tweaked driver at some point to get their system stable. The novice user would basically start the whole "awwww XP/Vista is crapz0r" when the machines gets unstable.
the p35 Intel chipsets support 45nm cpus and higher but usually only with a BIOS update - check with the vendor and make sure it will support 45nm out of the box or get them to update the bios for you. look into the Asus P5K .. very good value for money. The board design is a bit funny... the IDE connector is located in a ridiculous spot (not and issue if you're using a SATA dvd drive). long story short its a straight forward basic midrange motherboard with ok overclocking features if you wanted to experiement or couldnt be bothered.
The x38 chipset was designed for the 45nm generation, but its still a bit too expensive for my liking.
Motherboards are pretty clean cut - you pay for features. if you want more sata ports or an extra gigabit ethernet port or a built in wireless AP.. they cost more. If you dont want those features go for the basic board, and spend the dosh elsewhere.
The gigabyte motherboard mentioned above indeed has very good reviews, but I cant comment on it as i've never used it myself - i'm using a P5K on the otherhand.
besides the CPU and motherboard:
get faster ram try to get 1066 ram if possible if you're getting the 45nm cpu or 800mhz minium if youre going with the E4000 series. Dont get the fancy gamer spec ones with stickers and heat spreaders, the standard kingston will do.
ideally if you're using 32bit OS only (vista/xp) get 3 gigs of ram (2x 1 gig sticks and 2x 512 sticks - they all have to be the same speed (800, 1066, etc. Match the sticks to the ram slot color). if thats too much mucking around, just get 2 gigs or 4 if you dont mind losing 512mb.
Get a 500+ powersupply as well - look at the corsair range. very good value for money.
what case are you using?
Edited by Scratch
I'm getting a Thermaltake Soprano DX case, mainly because it looks nice and has plenty of vents for air flow.
So the 500w power supply is good enough?
I'm not really planning on SLI with gfx card to be honest but would like to have the option available.
I was looking at my choice of CPU and yes, maybe E4000 series is a little too mediocre so I may rethink to get a E6000 or E8000 cost pending.
MB I'm not too fussed about the functions, just the regular stuff - built in network plug, built in sound card and a few USB ports.
So for E4000 series CPU, go for p5ne-sli?
What's the recommended one for E6000 and E8000 series in your opinion?
Does that case come with the old 430W TT PSU like the old Soprano case (I have one btw)? If so, GET a new PSU & ditch that PSO.
When it comes to PSUs, the main thing to consider is the Amp rating on the 12V rail. The 430w PSU only has a single 12v rail with 18A on it & according to reviews its really only a 350w rebraded. With a 8800GT you should be looking at getting a PSU with a amp rating of atleast 22 or over on the 12V rail.
If its a good quality one (like the antec earthwatt or cosiar HX520) then yes, if its some cheapo generic crap (like SHAW) then no.
Another vote goes to the E8400, its easily the best bang for the buck CPU at the moment, already very fast @ stock (3Ghz) & can be pushed further quite easily. & since you are getting a 8800Gt you want a decent CPU otherwise theres gonna be bottlenecks, unless you heavily OC the E4xxxs.
As for motherboard, if you are not thinking of going into SLI then don't bother about the P5N-SLI board or anything SLI board for that matter as they are usually overpriced anyway. Just get a standard P35 motherboard. Like what Scratch said either a Asus P5k or Gigabyte P35 DS3 (or DS3L if you want to save a couple of $) I have a P35 DS3P & its a very decent board.
So the 500w power
Just the E8400, & forget about the E6xxxs, as the E8xxxs cost about the same as their older counterparts.
note: all of this is stated based on your intention for SLI:
Its good that you're looking into good airflow. the Gfx cards these days throw a lot of heat into the case, even when they have 2 slot coolers, 2 gfx cards will be killer. find the biggest case you can find you need lots of space for airflow. the soprano DX wont cut it. look at the thermaltake armour (not the jr version).
500W is not enough for SLI, you need go a lot higher. 750+ watt as a minium. you should also get low latency ram - if everything is up to par you get a 50% gfx improvement. Sub par= that figure dramatically drops. you need to invest in better cooling as well using noctua or scythe fans.. SLI isnt cheap :P
I've got the hx520 - i would have paid 40 bucks more and got the 620 instead but there was no stock.
if you're running non sli - 1 gfx, 3 case fans, 1 hd and 1 optical drive - 500watt as a minimum is fine.
the 8800GT are really popular cards.. looking back at history - these cards tend to run out of stock because of supply < demand. Nvidia is releasing a new gen of geforce series. they would be trying to push that instead of replenish stocks of the older card. This will affect your SLI propositions.. the new cards will be expensive and by the time you can afford them and updating system(mobo - ram ddr2 instead of ddr3, better cpu, better PSU). So if you're going sli do it on first base, or within the next 2 months.
yep if the e4000 is what you want.. you'll be fine with the p5ne-sli. Again, I wouldnt recommend the e4000 series because of their price point but i'm assuming your considering it because the motherboard which support 45nms and do SLI are still crazy expensive.
honestly - if SLI is what you want/consider getting... hold off buying a PC for now. Technology is shifting and you're not going to get good value (good value but not that much cheaper)
Edited by Scratch
In light of all the info above, I've decided against SLi, I'm not hardcore enough to waste that much time playing games.....so it's going to non SLi.
Guess I'll be going for the 500W supply with E8400 ecu. If there's still supply available for 8800GT I'll that.
Also been thinking about a decent monitor. I'm really wanting a good 24" one and I've heard Dell come up more than a few time. So far I see two model, the base model and the better model with the HDMI connection. Now, the Q is, if I went and bought myself a DVI to HDMI adaptor and used that on the BASE MODEL of the 24" Dell monitor. Is that going to have the same quality as the higher 24" spec if I play PS3 on it? It is a big difference between $600 base model to the $1k high spec model.
LCD you get what you pay for, mostly.
E8400
Thermaltake TMG i1
Striker II Formula
4GB 1066 DDR2
2 x 9600GT
3 x 500GB SATA 3G
SATA Blu-Ray
Antec P182
I feel a new PC coming on.
Edited by DivHunter
this thread caught my eye as my old pc has died . i do a bit of gaming mainly bf2 this parts have been suggested for my next pc maybe some of the more pc navvy smart guys can give me ther opinion ,
here goes intel cor dou e8400
gigabyte p31-ds3l mother board
8800gt gpu 512
psu 500 watt eartwatt supply
ram 2 x 1gbddr2800
do these componets look like they will match in well with each other i still need a case a hdd
thanks in advance dean
8800gt gpu 512
ram 2 x 1gbddr2800
Perharps change the motherboard to a P35 chipset one (the P31 is low end), like the Gigabyte P35 DS3L or DS3, DS3R or DS3P depending if you want extra SATA ports, Extra RAID levels & firewire.
Everything else seems good :laugh:
Yep p35 to match your 8400.. if you can afford it - push your ram to 1066, you will see a benefit in doing that.
look into the antec 900 case, check to make sure the 8800gt fits properly, the 8800gts was a tight fit, but it did fit.
500watt psu is minimum for one HD and optical with what you currently have + maybe 2 case fans. There isnt much difference cost wise between a 500+ psu and 600+ psu. Get the 600 and run better cooling.
Edited by Scratch
its the same as cars really you get different options and opinions eg: some people think split dump pipes are the ducks nuts and others say bellmouth ftw.
what you wanted originally is alright except:
1)get a dual core processor not quad.
2)get 3 gigs of non ECC ram.
3)Get a case with atleast 2 x120mm fans in it.
stuff you listed shouldnt cost you more than $1500
Edited by Scratch
  • 2 months later...
I just bought a computer!!!!! FINALLY!!!!
here are the specs
E8400
4 gig ram
2x500gb HDD
Asus P5K SE mb
Asus 8800GT vid card
550W PSU
Soprano DX case
and ..................Samsunng 2493HM monitor!!!! I am absolutely in love with this monitor, the colors are so beautiful on this mornitor and there's no glare. Also comes with HDMI slot, so I'll be trying this out with my ps3 once I get the plug.
nice, so were did you get it from and how much? The cpus have really started to come down a bit since we last left this, quad 6600s are now quite cheap, everyone is still going for the duals ATM until quads are needed.
so that samsung is a 24inch yeah? nice!
I would have absolutely no need for a quad cpu really, just the odd game here and there, mostly this is for movies anyway hence the large hard drives and big monitor.
and yes 24 inch samsung, but not the 245 model, this has HDMI connection which I should be able to use for PS3. i'm thinking of a TV tuner now so I can watch some nicer TV but these'll wait until later next month.
paid a total of roughly 1850, the system from MSY and the monitor came from HB outlet all of which you'll find on Pricespy.com.au.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
