Hey guys!
Just rebuilding my R32 GTR and wondering if anyone had the vaccum line diagram or photo for underneath the intake manafold
Theres a by-pass valve/unit underneath the manafold with a few vac lines coming off it and i dont know where it all goes. Alot of them have been plumbed off by someone else in the past
If someone knows where all this goes it would be a great help
Thanks
https://www.sau.com.au/forums/topic/203333-vaccum-line-setup-for-r32-gtr/
Thanks heaps duncan!
I'll have a look when i get back to work. I've got that service manuel too but sometimes its easier if you have an actual photo.
So much crap under that manifold. I guess thats the price you pay for having the best car in the world :D
Thanks again
the 2 vaccum lines (small hard lines underneath) are often blocked off with aftermarket boost control, you just take the feed from the rearmost exit from the plenum and run it to the solenoid, and then to the wastegates from there. Or is it something else they have blocked off?
well most the lines have been blocked with a bolt or screw. I've got like 4 lines that come off the idle solenoid that go no where, all blocked. Just wanna set it back to factory
I'll put it back together and when i do ill give you a holler. Do you work on these much?
I spent many hours on the weekend printing out the service manual and putting it in plastic sleeves in a display folder. It's way easier to read that way and it means you can have the folder (or page) in the garage with you when working on your vehicle.
Cost me about $60 in materials from officeworks.
If it looks like a pretzel it is the breather for the front diff. One end goes to the diff, the other is open.
You are my god!!!! I have spent many an hour looking through the service manual and even fast screens trying to find the blody thing
Thank You
  • 11 years later...
I take it the 2 lines ive marked in red are the ones that the hoses run from to the factory boost solenoid?
if so .. im running a greddy boost controller directly to the intake plenum and the wast gates so dont need to use it.. but i have lines
still running from them to the factory solenoid..if i remove the solenoid and the rubber lines.. should i join the 2 points together with a small bit of rubber hose of cap each one off separately?? just dont want to effect anything else that may or may not be running on either side of those vacuum lines..
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
