Check Ebay, Nengun, Greenline...
Samco do different coloured hoses, but you'll be spending around $500 or so to replace them all.
I just picked up some cheap blue Autobahn silicon hoses from J-Shop the other day for a bit over $100 (these are temporary hoses while I wait for my Samco hoses), however these are similar silicon hoses you can get off Ebay for about $80 delivered.
Edited by MattyP
https://www.sau.com.au/forums/topic/203339-water-hoses/#findComment-3607451
enthaily.com there a art an crafts wholesaler in qld BUT do silicon hoses and stuff and on there ebay page they catch cans an other crap. bought all my vac an intercooler hose stuff off them and have been excellent to deal with. many different pay methods to just like the suppliers on here. there cheap to. repco apparently can get the heater hoses i dunno who else in perth can get samco and others like that
Edited by turboedsloth
https://www.sau.com.au/forums/topic/203339-water-hoses/#findComment-3607571
In the last line of mods on the GTR, I replaced the water and oil line on the turbos with stainless braided lines and applicable fittings.. I went with the Horsepowerinabox line kits x2 and heap of additional fittings to get everything correctly hooked up, there was a bit of work in it, but at the end of the day it is far far better then the solids that I had before. It did however cost quite a bit of fold. I ended up doing about 3 orders in total and Maurie and HPIAB helped me out with all the fittings that I needed. If i had access to my old emails, I'd tell you exactly what I got, but I just moved and my PC's are in storage.
https://www.sau.com.au/forums/topic/203339-water-hoses/#findComment-3616038
Ok, so there isnt any specific improvement related reason one would change them then?
one thing i can note on is that when you remove a solid line (banjo bolt) you also need to replace the copper washers with new ones every time, the speed-flow/earls dash fittings being a screw fitting eliminates the need for this every time you remove the connection.
very handy if its a part that frequently needs to be removed (hence why drag and race teams dont skimp on fittings)
https://www.sau.com.au/forums/topic/203339-water-hoses/#findComment-3626420
If you are thinking of doing vaccum lines and that, the best stuff is the blue stuff from go-gear, but im not too sure if its ok to use a water lines.
Steve
i bought 5 metres from go gear at around 60 dollars, then bought 20 metres from chris mills performance for 40 bucks... exact same hose.. Chris mills only sell it in bag lengths of 10 metres.
4 and 5 mm is the common size for the vaccum lines on skylines
https://www.sau.com.au/forums/topic/203339-water-hoses/#findComment-3626438
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
