***new Date***cruise Throught Old Pac To Wisemans
  • Replies 117
Posted Images
Well i havent driven through soooo much rain before!
Nice to see a few guys out, Zilch nice to meet u mate i couldnt believe how much rain round Hornsby & on the way back, i was aquaplaining at 60km before berowra turn off on th F3!
The way back was F*cked too went through some huge puddles/mini RIVERS!
& to top it off my dam Demister for the windows was working shit! Had to wipe my windscreen every 5 mins!
Made it back, man some of those flooded road bits of the Pac hwy round asquith etc were deep!
Mate I had the demister problem as well, due to my gauge wires coming up through the air con vents on the drivers side, my mate could see fine in the passenger seat! I hit one very bad puddle that slewed me sideways into the bikelane but luckily no harm done.
Was good to meet both yourself and Warlord, now then.. Surf's up? :)
I just came back from the Coast (stopped at Thornleigh Macca's for a quick bite @ 1.30pm) and had no troubles in the rain, even on my shitty tyres. Had a fair bit of rain on the F3, but nothing I couldn't handle and feel safe at at the speed limit.
the sun is out ,birds are singing,the morning dew on the grass are like diamonds and its not on cos of the weather * * * * * * * * * * * * * * * * * * * * * * * * * * * * your kidding,now i have to go shopping with my wife ,thanks .
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
