  • Replies 327
Posted Images
Gearbox not in but i dont need 3rd for a dyno comp. Besides i have to beat my PB of 301awkws
You running her???
You'd better! I've never ran mine on an awd dyno!!!
BTW hit 76 on the knock today on high boost, never done that before........random I guess.
C y'all there.
Hills Motorsport is located at Unit D6, 2A Victoria Ave, Castle Hill. It's the complex on the corner of Victoria Avenue and Windsor Road opposite a big Holden dealership (same complex as UAS used to be in) and it's up the back on the left.
Hills are putting on a free bbq for us and supplying some drinks. There is a drink machine if they run out. They should have some chairs in the shade and will have a screen for us to gawk at.
DON'T FORGET, IT'S ON THE 1ST OF MARCH
There ya go, Ben!
Oh, and come and see me for SAU MERCHANDISE!!! - Support the club that supports you!
Ah dammit...
I was in Sydney yesterday and will be back in again tomorrow - but not today.
AND I know exactly where that 2A Victoria ave complex is, and I don't know Sydney very well at all.
Would've been good to put mine on the dyno again because I changed my exhaust system yesterday.
Ah well, have a fun day everyone :P
Yer seemed like a number of cars still going on the dyno when i left at 2pm mine nowhere near what i thought it would but can still keep up will GTRsean.
i made 282awkws and GTRsean 322. O well bring on the Pics aleast my car looked good for a change.
yeah was good to meet new people and catch up with the oldies.
Id like to apologise for not being myself today, yes, self inflicted I know, but I was sooo hungover it wasn't funny (to me anyway!)
Big cheers to Adam and Hills and everyone else involved.
Oh, and watching Josh get 301rwkw in his cammed VX SS makes me want an LS1 again....
:P
Hey folks great to see such a good turn out. For those that wondered why mine came back off the rollers before a run my front clutch pack is stuffed so I didn't want to do it any more damage. Geez out comes the VISA card again!
At least this confirmed it before I did any more damage out at power cruise. I hate it when my toy is broken :P
Glad to see so many tough machines today.
Was a great day and wanted to stay longer but had to leave at lunchtime to go do a gearbox ;)
Big Thanks to Hills Motorsport was a excellent venue and Mark and all the guys and girl were so nice, was cool to meet you all!
Big Thanks to Adam and all the SAU peeps that helped out on the day!!
Hope my cooking skills were alright on the BBQ :)
Cant wait to see the results and pics!! :P
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
