Hey guys, looks like I'm going ahead and finally getting myself a nice GTR ;) Problem is I need a standard bonnet and possibly drivers seat that I can borrow just for the visual inspection at Regency. Anyone able to switch their bonnet (preferably white) and drivers seat just for a day or two? Or even know somewhere I can loan them from?
Cheers
https://www.sau.com.au/forums/topic/203695-need-to-borrow-some-parts/
Cheers
I'd strongly suggest you get a white bonnet as well !
I like that car man (if its the same 1 u showed b4) !
See if what is an issue Nick? The CF bonnet? If so I believe it is as AFAIK they need to meet ADR standards. But please by all means if you could give me the number just to check that would be awesome :)
Luke the no for Vehicle standards at regency is
1300 88 22 48
had a quick word to a friend down there and she doesn't think a carbon fibre bonnet will be a big issue. She said to watch out if the car is noticeably low or has a f'ing big exhaust on it. She recommends sturt over regency aswell.
I tried to call them today but got called out of the office so i couldn't stay on hold. It may take awhile to get through, other times i have had someone answer straight away
good luck with it all
U work at regency? Or are u offering to pay for his 2nd trip back when/if they defect it for not meeting ADR standards?
How about we leave it to him to ring regency...
He is welcome to do as he pleases, he has also seen my bonnet which was fine when i approached regency regarding its legality just 3 months ago.
EDIT: After inspecting the pics of the car, it is in fact the same bonnet.
Edited by fieds83
No problems, i went in and spoke to a gentleman at regency regarding a range of mods on the car. As you remember it was extensively modified and according to him the only thing that needed to be done was raise the car, remove the tint, remove the computer, injectors and baffle the exhaust. To some that may sound like a lot but the list of things that needed to be removed was shorter than most would think.
Things that were fine were on my car:
19's
carbon fibre bonnet
coilovers(though needed to be raised but being adjustable is not a problem for regency)
hks filters
intercooler
two boot mounted 044 bosch pumps(he stated that the pumps were fine but the original computer and injectors would need to be in place).
I did the research first so that if and when i wanted to change the vic reg over to sa i would only have to go through once. Obviously Luke yours has some slightly different mods in other respects but the carbon bonnet will be fine according to the gentleman that i spoke to at regency.
He actually stated to me that yes the cops may have a problem with some of the mods but they were by no means illegal and would not have a problem passing an inspection.
Still, give them a call or drop in regarding all your mods before you go for your inspection just for peace of mind. They wont defect you over the phone or counter, they will appreciate that you are trying to comply with their standards.
Edited by fieds83
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
