i have recently purchased a r32 gts-t, now i dont know to much about them or any car for that matter.
i want to set up my suspension for drift with a few hill runs. thats ok because i can get to a wheel alignment machine when i need it.
i dont care how rough the ride is, as long as the chasis and mounts can handle it, and as long as it handles well.
1st of all i want to upgrade to coilovers, which would you recommend? and what rates? anything inparticular i need to know before i go out and buy some? what should i look for, and what should be adjustable in them.
i plan on rehauling all(most) my suspension components. what else should i look at changing. sawy bars, strut brace, castor rods... anything else im missing feel free to add, im just drawing up ideas atm, i plan on getting these parts in about 2 weeks when i have some cash, and im back at home.
cheers, issa.
https://www.sau.com.au/forums/topic/203953-suspension-for-my-r32-gtst/
I suppose it comes down to how good you want it to handle and how you want to go about it.
There's a hell of a lot of info floating around in this section but in general:
Don't buy a $1300 set of coilovers, no matter how pretty they look. Don't get silly hard spring rates. 7/5 would be the sensible upper limit (and i'm sure some people will say thats to hard as well)
Get some form of adjustable caster rod (I'm not going to go into the benefits of poly over rose joints here)
Get some form of adjustable upper arm for the front
Get some form of adjustable upper arm for the rear
Get some swaybars
Lock the hicas
Get something to tighten up the rear subframe (either re bush, alloy collars or poly pinapples)
Get some good tyres or you've wasted a lot of money on the other bits
Edited by BHDave
Get some swaybars
Lock the hicas
thanks so much for the help mate, appreciate it.
what do you mean by the upper arm's. as in adjustable camber tops?
or
strut braces?
im gona get hicas taken care of as well.
thanks alot, issa.
r32's dont use camber tops. You have to get an adjustable upper control arm, whether by adjustable bushes, or a whole replacement arm that has some form of adjustment.
The rear is the same, though much easier to get as it's common to the s13 as well so plenty of options.
Front strut brace definately, rear strut brace if you have a spare 150 dollars
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
