While idling the engine 'blips', just a lumpy idle really. I did a bit of research and found it could be a problem with the RB25 throttle position sensor. Is there a connection?
I cleaned my AAC valve and AFM but didn't fix anything.
Any advice?
https://www.sau.com.au/forums/topic/204062-idle-issue/
good old nissans...never idle properly.
could be coils, plugs, tps.
I've done plugs recently. So that leaves coils and TPS.
I read the "tape your coils" thread, so i'll give that a try.
What are the possibilities it's the TPS?
https://www.sau.com.au/forums/topic/204062-idle-issue/#findComment-3623126
Yeh i'll reset the ECU, though i doubt it'll fix it.
My rpm's aren't affected but i can feel the engine vibrate, even with music pumping (no sub :blink: ).
I'm guessing there's some magical thing i've missed that needs cleaning/fixing
https://www.sau.com.au/forums/topic/204062-idle-issue/#findComment-3624070
  • 1 month later...
this is what mine does, is it sorta the same thing? i also cleaned aac valve, regapped plugs and cleaned afm but nothing helped. My next try will involve dumping it at a workshop and praying they can fix it!
http://youtube.com/watch?v=02Cyv2CWqDU
https://www.sau.com.au/forums/topic/204062-idle-issue/#findComment-3747226
My car was idleing like that just after i fitted the new turbo that had a .7 comp housing and still managed to have the stock afm attached thanks to some attachments. 2 days later i fitted the Z32 afm and a retune and now it idles fine...
Maybe its the air flow meter if u havent touched anything recently?!
https://www.sau.com.au/forums/topic/204062-idle-issue/#findComment-3747824
yeah, mines doing the same thing..and i thinks it getting worst!!!
(MODS)
i drive a r33 s2 skyline..
i got a hks exhaust, 3A Racing POD, FMIC,greddy ATMO bov, splitfire coilpacks, re-gapped ngk iridiums plugs to 0.8,
boosted up too..running on 12psi, and got an ApEXI NEO (and had tuned twice)
(ISSUES + CURRENT PROBLEM)
and now im getting really bad flat spots, bad idle etc.. lol and hunting issues again..which wer all gone..
but now everything is back at once..lol
(WHAT I"VE TRIED)
plus ive tried cleaning throttle body, intake manifold with forton carby cleaner(the best stuff u can get)
cleaned the IACV(the 3 bolts that are on the end of the manifold) took it off and gave it a good clean etc..
but yeah evan sprayed vac line that gone down to the IACV.. tryed cleaning afm with electrical contact cleaner too..
(MAIN PROBLEM)
idle issues wen starting the car are now gone..but yeah
hunting issues wen clutch in/etc..
revs drop down to like just under 500rpms...and then from there it will start hunting..
only sometimes it will do this...usually it will go back up to 1100rpms..but other time it will hunt..
it like it trying to prevent itself from stalling..???
hunting pretty bad...
(APEXI NEO - DEC AIR SETTING ISSUE)
i've looked on my setting on the apexi neo..
the DEC AIR SETTING isnt turned on, i believe...it say's off,
and then i cant turn it on,(its not anon/off type select...
it goes and changes to %..and starts from 0%..s wer do i put it too???
so yeah, a bit confused....
so anybody now u to use this setting??
and do u reckon a z32 afm and new fuel pump + a re-tune will help???
https://www.sau.com.au/forums/topic/204062-idle-issue/#findComment-3773109
i reckon get rid of ya atmo bov and it prob will solve ya problem
the bov is fine..and ive had it for months..no problems..the second time i got my car tune..i fixed the bov
problem...so i dont think its related..
https://www.sau.com.au/forums/topic/204062-idle-issue/#findComment-3773152
  • 4 weeks later...
there are a few known causes of idling style issues. dirty contacts (AFM or TPS), worn out valves (AAC valve), and other wear style issues (wiring, coil packs etc).
these would typically result in unstable idle, fluctuating idle, or blipping style idling - the r33 service manual would list several fixes and corrective measures for this, you should download it and have a read
the engine rpm dropping to 500rpm (almost stalling) on clutch in is usually associated with an atmo bov
its been covered to death over a 100 times, its always usually the atmo bov, it dumps air that the AFM has already measured
so the mixture is out of scale, as the air is missing so the engine overstalls and rpm's plummet
https://www.sau.com.au/forums/topic/204062-idle-issue/#findComment-3845075
would a atmo-plump-back type bov fix this problem???
lik i have the choose to make ot plumb-back and atmo..
coz on my 33 now ive got a greddy type rs atmo bov..
which has an a key on the top to adjust the spring inside...
mit adjust that abit harder and c how i go...
https://www.sau.com.au/forums/topic/204062-idle-issue/#findComment-3847652
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
