how much does a dry setup run for you guys down here its not to expensive i can buy a slightly used setup for about 1200 with the sump fabrication, im in peru man aeroquip fitings are made here, stainless steel meshed lines all made here , i hear it costs you guys about 7000 dollers to repair an engine in machine shop costs, down here ive go it all done for 400 dollers, how much do you guys think it cost me to put a 1ggte in my ae86(2.0 twin turbo inline 6) cost me 300 dollers painted with intercooler piping ran a 12.3 with that car(ofcourse i have to guide them a little bit but man a1 work), diffrent worlds, here profesional labor is super cheap minimum wage is 200 dollers a month, a flow tested port in polish and 5 angle valve job cost me 380 dollers, but i honestly dont think ill have lubrication problems
Edited by ReganGTS25T
who spun that? maybe im outta the loop but i can get a jun pump for under a grand but have no chance of doing a dry sump arrangement for under a grand.... maybe my supplier is jibbing me :)
just curious how much do you get a jun pump for, in the states the greddy is at 1000, the nismo 1 is at 1200
How did the last owner manage to do that?
im the first owner of the car the importer's mechanic did that when the car didnt want to start lol, i guss he was trying to take the fuel rail out without taking 1 of the screws or something like that lol, its either that or they used it to hit some 1 lol
i would be more concerned about head lifting and and main caps walking ... before you put the sump on fit some ARP main studs or else the rods and so forth are a wasted excersise...
Have you ever had problems with ARP mains in the RB's when torqueing to ARP spec's?
Ive had loads of problems with them in SR20's pulling the block slightly and causing crank bind and finding people in South Africa to line bore SR20's is a real challange, left me with sour taste especialy when you have to grind 2 of them down so it doesnt crack the oil pan. I normaly use all their studs besides the mains, but with my RB I will need to upgrade but I really dont want to line bore a 11 000km old motor.
from memory it is 65ft/lbs..... which is not real tight. The only issues with SR's and ARP's is the fact the alloy middle sump sump section fouls and requires the removal of 3-mm off the top of those two ARP studs.
im doing another as we speak.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
