hey guys.... i have posted previously about a noise under my hood.... and now i have just had a good look at the turbo..... from the front... when i grab the main axel ... and give it a giggle... it moves a little to freely for my liking... what is this in the turbo that needs fixing... bastard of a thing!!!... it got rebuilt like no more than 3 months ago!!!.... by garrett...what junk~!!
https://www.sau.com.au/forums/topic/204281-t04e-garret-turbo/
turbo needs a full rebuild if the wheel moves side-to-side
sounds like the turbo wasnt balanced correctly initially, or something has upset the balance after it was performed (turbo dropped, foreign object hitting the wheel under RPM etc)
Being a plain bearing unit, expect that it will have some movement both end-to-end (thrust), and side to side (radial); more that you would experience with a BB unit. In operation it rides on a high pressure film of oil that takes up a lot of that play.
If there appears to be a genuine problem with your rebuild, then the best advice is to get in touch with the servicing agent for a warranty claim.
yeah the comperssor wheels gets like so close to the housing.... but i think under pressure ect it would touc for sure... i can see the scratch marks!!!... actually. i was just in the middle of pullin it out and have myself in a pickle of actually getting the thing out!!!... the turbo is high mounted .. i have undone all the dump pipe nuts and that is loose ( no gasket in there??) and under neath the 2 bolts closest to the front are undone... but the ones at the back cant come of cause they are blocked by the dump pipe//.. i cant get it out,,,any ideas??... oh,.. and when undo the oil lines...should i undo them at the turbo or like at the next join which is the hosing??... sorry guys but i hate my car in bits...HELP!!!... cheers alex
