Well, its another of those "gimme gimme" threads!
I have decided to shave my scone to raise money for the leukemia foundation by taking part in thier "Worlds Greatest Shave" so how about slapping a few bucks down to help save the life of a patient of a b@stard cancer that eventually WILL be cured, with enough support for the research.
http://www.worldsgreatestshave.com/profile.php?id=391216
Go to that link to donate, leave thinly veiled offensive encouragment and in the next day or two I will be slapping some before photos, and then the end result will be posted in this thread for the enjoyment of all (except me)
https://www.sau.com.au/forums/topic/204547-worlds-greatest-shave/
OK folks, I have updated my before photo (no more fat gymp waiting to be disciplined :P ) so ante up and
SHOW ME TEH MONEEEEEEEY!
Srsly folks, this is for a really good cause and together we will be helping a lot of really sick kids (and their families) make the most of a really horrible situation.
  • 4 weeks later...
You mean bastard. How could you just sit back, and watch females losing what is very likely their pride and joy, and not post pics somewhere?
I dunno, young blokes of today! *wanders off mumbling*
Srlsy, yes it does all go to the same place, so good on ya dude.
Anywayz,
Before
During
Stinky Chicken joins in the fun
The Good Wife gets carried away
After (thanks for teh finishing touches chuckie :D )
And a huge thanks to everyone that donated. A lot of familes affected by this terrible disease also thanks you.
dancing 'nana's for all!!!
:D:):(:banana: :banana: :banana: :banana:
Jeez, you didnt even go the shave lads. Dissapointing.
You are actually not allowed to go down to the scalp. Something to do with health issues and liability...
anywayz, my head is still farken freezing, and a 30 knot easterly on my walk to the train station this morning didn't help :(
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
