  • Replies 487
Posted Images
Can I enter my bike doof? :P
I think you can actually... I wonder if you can like enter 3 and only pay for the one spot... hmmm :rofl:
faxing right now!
Received just then I do believe Jeremy... if that IS your real name :D
yes yes, hence the use of the :D emoticon
So that's 7 entry forms, and still have to get Pauls and Yidz forms, and I have one more entry to sort out... IF they wanna enter :O
Hey buddy I believe Paul's sent them off yesterday at some stage...
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
