hey
im wanting to get a round about speed for a 7k(just on redline) 3rd gear
for example if u were in 3rd gear and u had ur foot flat to the floor and hit redline what speed would u be round about for a stock 32?
this is a serious question dont flame my speedo is out and i dunno if gps is correct so im wanting to get an approx speed(i have googled cant find it)
https://www.sau.com.au/forums/topic/204732-r32-gts-t-3rd-gear-max-speed/
This is a theoretical calculation using the r32's gear ratio/diff ratio's.
Although no doubt wind, inclination of road, resistance will affect the actual speed
someone will have to double check the rpm at 100km/h on 4th gear though :)
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
