Any one out there with an R32 or S13? You sick of the rear axle tramp on hard launches? Want better take off? OR How bout making the rear more predictable for drifting?
I HAVE YOUR ANSWER => PINEAPPLES
These are urethane rings that solid mount, and modify the angle of, your rear sub-frame. There are two methods of installation, GRIP and DRIFT. This modification to your car is completely reversable, can be changed between GRIP and DRIFT in around an hour or so, and greatly reduces axle tramping.
These 'PINEAPPLES' have been marketed by Japanese Motorsports in Adelaide for $150 for a while now. I have found a local source, and can supply them for $110 WITH ENGLISH INSTRUCTIONS.
I can also fit these to your car if your in the melbourne area.
PM me, E-Mail me at [email protected], or call me on 0411 878 961 if you are interested.
https://www.sau.com.au/forums/topic/2048-get-rid-of-axle-tramp-r32-or-s13/
Nope, axle tramp is when you get wheel spin and your wheels and subframe 'bounce' a bit and cause major vibrations through your car. Of course bouncing wheels are not good for take off. If you need further explaination call me on 0411 878 961.
Doc.
Doc,
Can you explain where and how they mount. I've seen the pineapples on JMS that your talking about, but I could never workout where and how they work.
Do they work like a shock absorber for your sub frame or something?
And how do you change them between grip and drift? Is it just locating them in a different part of the sub frame?
And the big question (and last - sorry :P ) are they legal???
Thanks
J
Ok, There's four main bolts that hold your subframe on. All of these bolts have rubber bushes in them that allow the entire rear sub-frame to move around. Pinapples reduce the movement of these bushes.
You can mount the pinapples either above or below the subframe to take up the movement. These particular ones are designed to mount diagonally opposite, IE Front Top & Rear Bottom OR Front Bottom & Rear Top.... When you take up the slack in this manner it will slightly rotate the entire rear subframe, and hence your lower control arms. I believe it is this change in angle of the lower control arms that gives you your different handling characteristics.
Switching them over is a simple matter of removing and refitting by the other method.
LEGALITY => I have no idea, and refuse to 'guess'. You would need to speak to an engieeer for approval. I would simply paint them black when fitted and plead ignorance if it becomes a problem.
J, Hope this helped your curiosity. The JMS instructions are in Japanese and difficult to interpret. Call me if you want to discuss? 0411 878 961
Doc.
J,
What sort of car is it? Changing tyres wont help, I've tried it. Some of it is due to shockies but most is due to your subframe moving aroung.... Keep me posted if you want me to order a set.
Doc.
Doc,
At the moment I'm running Sava Raptex's - I must say that they are the worst tyres I have ever run on ANY car !!! But when I got them I was strapped for cash and needed to go over the pits - I really can't complain as they cost me $93 each (225/50/16's) and I've got 12 months from them.
I'll be getting the Dunlop FM901's in the same size so I'm hoping for a massive increase in traction :P but as you said, I'm not sure if they will fix the axle tramp. The suspension is pretty tight in the back (which doesn't help).
I'll let you know how I go after the new tyres go on.
Thanks
Jayson
The car is a R33 GTS-t.
Dig this - just did the phone around to get some FM901's (225/50/16). Prices range from $200 each to $271 each!!!!
Apparently Dunlop have put their price up as of tomorrow, so for any store that needs to order them in they have to quote the higher (after increase) price !!!!
I've found a place that has them in stock so I'm hoping to get them before the weekend........
Sorry - that was a bit off topic - I was just shocked !!
J
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
