starlet GT engines are awesome little things. I have one in a mini (old schooler), its not running yet. A couple of people in Aus are have them in minis and running 12sec passes out of the box.... For sure they SNAP my skyline
DRP-OOF - why are you posting in a thread about starlets then?
Monkey - I'm comfortable on my horse..
you two lesbians need to chill out.
Cause I have shit to say... and again, you're defending yourself... stop arcing up so much...
and heaps creative on the letter there... my plates were actually 'modified' once with white-out and a pen :P
So you're not the first...
there is no "factory" supercharged/turbo starlets.
I'm sure it's doable, but would be a lot of money for nothing.
I'm assuming you have the aus delivered shopping trolley version.
you can turbo charge that..
or engine conversion from the jap spaec EP82 starlet which has the 4e-fte turbo 100kw engine.
Sydneykid had once mentioned that he knew of someone who had shoehorned a sivler top 20 valve 4age in to one.
those motors are 118kw I think..
was apparently a bit of fun to throw around.
FYI to the above - there are starlet GT's - turbo from the factory...
i was thinking about buying a turbo stalet a while back. they do a low 15 second 1/4 stock, so a few mods like exhaust, cooler, and more boost and you should be into the low 14's pretty darn easy, and still have a car that you can park in the trolley bay at coles.
thats it hey, can be a nice quick commuter!!
I should have typed that as supercharged+turbocharged.
I initially thought the OP was asking to supercharge his already turbo starlet.
as in, I thought he had a Starlet GT which he also wanted to supercharge.
like twin charge.
make up your mind? or were u implying there were no aus spec turbos?
i had a gt starlet years ago.
ran a 12.9 at wsid on street tyres with only the following mods
trd lsd
new manifold with wrx turbo to suit
full exhaust
fuel reg
fuel pump
dont know bout you guys but for those mods thats pretty dam quick. cheap awesome little car in my opinion
yeh I described what I meant 20 mins before you posted... just above this post.
trd lsd
full exhaust
fuel reg
fuel pump
that was the $5K I was refering to.
got it from Dale? (10secrx7)
he has/had a upgraed package of:
manifold
TD04
Microtech and tune
and a few other bits.
was under $5K from memory and pretty much gave a power/weight to run a 12.xx
then it was a matter of driver ability and traction.
"When threads turn bad..." haha
I rem when my cousin got me into cars, mid 90's. KE Corolla's, Cordia's, NA Rotary's were the bread&butter. 11sec Sigma turbos would eat you, and in cabin, screwdriver tweaked Microtechs was NASA stuff.
Ahh the good ole pre-adolescent 90's; wet dreams, women and umm... worcestershire sauce.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
