hi all...got a S2 R33 and wanting to put on an exhaust system on my car....
what is the best type/setup for the liners..? how many inch wide pipes etc....
i also want it to be on like a switch or something so that i can have it on silent from time to time and be able to switch it to loud jus by flicking a switch....
can u let me know the systems that have this type of capability or what i should be looking for in order to have this type of setup...
Cheers
Matt
https://www.sau.com.au/forums/topic/205370-which-exhaust-system/
i think this is what u are looking for
http://www.importscene.com.au/prod466.htm
As above...The Jp systems are the best bet. They come with a Db rating so you have some confidence that you "probably" wont get defected. Switch-Apexi do a valve that can restrict the noise but i dont know that i'd want that. The quality systems sound fine anyway. Size-3 inch is fine for a "line" under 400KW
oh GL with it. lol
nice....i lol at ur 'GL with it'
see as my av says....now ur a big man!
i have been recommender a HKS Super Dragger....any thoughts?
pro's and con's experiences.....let me know...
The HKS Super Dragger is very old and is no longer made.
Your best bet is to get a quiet street system, like the Kakimoto Regu 06&R.
I have seen a lot of different exhaust systems out of Japan and in terms of build quality, the Kakimoto is up there as one of the best.
Hey mate i just installed myself yesturday the Kakimoto Regu 06&R exhaust. I also used a just jap front pipe and cat.
Sounds quite on idle but then when you put your foot into it sounds great!! not a drone, not farting but a reali nice sound. Was reali suprised how nice it did sound. And for the cost it was quite good. Looked well made etc etc
Wouldnt change it for anything :(
Buy a decent Japanese made system, turbo back. Dont go cheap, the drone will annoy you.
+1
i like the super dragger also
but like Blitz said, no longer in production
looks sexy as
does anyone know what the JJR Hyperflow exhausts are like?
Droney... :) Actually that is what I had and I sold it as I could not stand the drone after a while. They are cheap and give good power, but you really NEED an extra oval resonator in there instead of that canon or weld one in the middle of the exhaust!
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
