  • Replies 200
Posted Images
No one bitching in your ear + good music = relaxing :P
I'll try and be there despite work, hope the weather is good and look forward to meeting you guys
Yeah true that! I didnt think of it THAT way lol
YAY! should be great and i cant wait to meet everyone. :D
At this stage my car is MIA. I'll be getting the fuel pump fuse-blowing incident sorted this week so i'll still make the cruise if all pans out at the workshop.
Omar, no excuses.. Your coming =)
The List so far:
R34 GTT Black - Assasin
R34 GTT Black - GR34TT
R34 GTT Black - DECIM8
R34 GTT Black - Alien
R34 GTT - Anna34
200SX Silver S15 - JPS200
200SX Silver S15 - Ryan
200SX Green S14 - Eddy
S13 - Ignuz
Mazda RX7 Green Rotor (HOT 4's Mag) - Paul
R33 Black - CTF_r33
R33 White - Charlie25T
R33 Grey - R33BOY
R33 - OMGRLX
R33 Gts-t - Slverbullet
R33 Gts-t - Zilch*
R32 Gts-t - allthewaytotheskyline - DVSR32
R32 GTR - Rozza
350Z Silver - R34NOS - 4RANSM
V35 350GT Silver - russky
i like the full organised list u have there!! :)
Edited by gr34tt
The List so far:
R34 GTT - Anna34
S13 - Ignuz
R33 Black - CTF_r33
R33 Grey - R33BOY
R33 - OMGRLX
R33 Gts-t - Zilch*
R32 GTR - Rozza
i like the full organised list u have there!! :D
man i saw u driving down george st yesterday afternoon.
car sounds awesome
The List so far:
R34 GTT - Anna34
S13 - Ignuz
R33 Black - CTF_r33
R33 Grey - R33BOY
R33 - OMGRLX
R33 Gts-t - Zilch*
R32 GTR - Rozza
Of course my friend.. We'd all be a lost cause if one of us wasn't organising! LOL =)
u have a gud point there my friend!!!
Hey mate,
Put another 2 down for the cruise. Me (terry) any my brother-in-law Michael will come down in our new rides..
mine is a White r33 GTR V-spec GTR-98L and my Michaels is a Silver r33 GTST TBA.
This will be our first cruise so go easy :D:) ...
JOKES. Look forward to seeing you guys there.
Hey folks, I might try to come but have a full car weekend with powercruise this W/E. See if the wife will let me out two weekends in a row.
Looks like you need an R33 GTR V-spec hehe!
Looking forward to meeting you champ =)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
