Still got it.... Have had an offer for $180...
Brand new cndition, I still have the box/manual/original face plate aswell....
Im looking for it to go over 220....
Their still $569 at the optus shop brand new....
https://www.sau.com.au/forums/topic/20552-nokia-8250/#findComment-447848
