hi all,
i need some good oil but can't find a local stockist
dose anyone know where i can buy Motul turbolite 4100 10w 40
off the shelf.
i know it can be ordered but i don't have the time to wait for it
The closest so far has been dural *ftw
any help would be great
Edited by Y2K2
https://www.sau.com.au/forums/topic/205667-where-to-buy-motul-4100-10w-40/
hi all,
off the shelf.
I thought auto barn had some
auto one - chatswood and hornsby are not stockists any more
auto barn - closest is dural
repco - waitara:NO dural:should have
realy can't afford the time off to go get it
any other sugestions
order it from Just jap or somewhere close and get them delivered to y our door?
Where To Buy Motul 4100 10w 40?
Ans: Don't Buy Motul 4100 10w 40
It's only a semi-synthetic
yep. exactly. well I did try to tell him before but clearly he's not keen on the advise. 4100 is a pretty ordinary oil. I certainly wouldn't put it into any of my cars.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
