WOW , what a f***en awesome night :laugh:
Went to the Sat night show, easily the best night of my life..
Anyone going to Armin next month ?
Yip! I will be!..
Im in the process of selling my kidney to fund the ticket.. but its ok!.. it will be worth it!..
Anyone have pics/vids from Tiesto's show?
https://www.sau.com.au/forums/topic/205681-tiesto/page/2/#findComment-3845732
IMO it was pretty average (Melb show).
I've got a few pics i'll get around to putting up at some point in the next week perhaps.
Overall i was glad i didnt have to pay for my ticket as $100 IMO it wasnt worth it @ festival hall
Going to Armin in May, so see if thats any better... cant remember if im paying to go to that one either hehe :blink:
https://www.sau.com.au/forums/topic/205681-tiesto/page/2/#findComment-3846810
It was a great night, the best tracks were from about midway onwards and the end was nuts. As Tiesto came on a couple girls to my left were cheering AND crying lol what the!
Though the concert would of been better if it was at a larger venue for sure - Festival Hall was a wee bit small... one MASSIVE concert instead of multiple small ones would of been much better.
Plenty of videos on youtube
Edited by typevu
https://www.sau.com.au/forums/topic/205681-tiesto/page/2/#findComment-3847968
hahahaha i went to the 2nd and 4th shows
oh i also bought 23 tickets and sold them all on ebay and forums for an extreme profitable margin
i would have bought more but the credit card said no lol
cant wait till summerdayze to do it over again lol
got my armin tickets as well but sold them all to friends for like 10 bux profit, kind of angry about it actually
https://www.sau.com.au/forums/topic/205681-tiesto/page/2/#findComment-3862301
[quote name='GUN_METAL_GTR32' date='13 May 2008, 12:45 PM' post='3862301'
If i made a profit off my freinds they would never talk to me again.
https://www.sau.com.au/forums/topic/205681-tiesto/page/2/#findComment-3862938
ferry corstens playing here in tokyo AGAIN tonite :)
i saw him 2 years ago at future music i was all the way at the front , it wa amazing.
when i think about tiesto i want to cry, i nearly started to tear up when he came on stage at festival hall lol
https://www.sau.com.au/forums/topic/205681-tiesto/page/2/#findComment-3877100
  • 1 year later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
