Can anyone tell me roughly how many k's I should get out of a full tank of fuel in a 97 RS4 Stagea in standard form.
I have just clocked my last ful tank at 360k's which seems very low?
If this is the can fault coil packs cause this high consumption as the car does not appear to be running rich. However I do have this pulsing problem over 70kmh as posted on another thread.
Does anyone have any ideas
Cheers
Bakes70
https://www.sau.com.au/forums/topic/205752-fuel-consumption/
  • Replies 70
ok when I bought my stag the SAFCII hadn't been tuned and I was getting around 400 per tank city driving and well over 500 per tank on the open highway (drove from SA to WA)
With it tuned now, I get 460 per tank... city driving.
I've got 345 on the clock with just over a quarter of a tank to go and I'll get atleast another 100km from it.
Thats on BP Ultimate (98ron)
Edited by StageaGirl
Thanks for that. I have a stupid question now what is the SAFCII?
Also are you in Rockingham, Perth by any chance...if so were did you take your car to get tuned.
Cheers
Bakes70
i had shot coilpacks with my rb25. they gave chronic misfire on full throttle at 4000rpm and above. however this made me drive the car nicely so i still retained great economy.
remember it also matters how you drive it, i can get 20% better economy if i'm nice to my car.
check your 02 sensor, they're meant to be replaced every 40 000kms iirc
and google SAFCII to find out HEAPS of info :D
bugger all mate, even when working perfectly they are thirsty if your foot is heavy.
and mine is. really heavy.
mine is manual, new 02 sensor, airfilter and exhaust on the standard computer, and I am happy if I get 400klm.
About to put a power fc in and see if that helps, but I'm not expecting an improvement
360km isnt bad, honestly.
when I first got mine I got around 410kms per tank to around 55L
then tuned, a little less kms but more power
and again
and again
now Im limited to 90kms per quarter if I pussyfoot for 80% of the tank
the other 20% makes it worth it :laughing-smiley-014:
and again
and again
Cheers for that. I just wanted to get a handle on how thristy they are, and if my problem was fuel related.
yeah I'm in Rockingham... I took my car to Hyper drive when I first got the car.
I also run 7-9psi now too, instead of 12 lol
Super Air Flow Controller (SAFC) it modifies the air flow meter signal to trick the ECU into thinking that there is less air going in to the engine, to send in less fuel, as the stock ECU tends to run quite rich with mods. (all that info from Mitchy)
I am in Rockingham too......I am running just under 7psi boost but everything else is pritty standard. Do you know anywere local that could tune the SAFC on my car.
Cheers
Paul
SAFCs will have minimal effect on your economy, as when you are cruising (closed loop) the ECU reads the O2 sensor and constantly adjusts to achieve the preset mixture. The SAFC will save you some fuel when you are hard on the throttle (open loop), where it uses the air flow meter signal. A lot of tuners won't even bother to tune the low throttle map on the SAFCs, as mine did.
http://www.hondahookup.com/forums/showthread.php?t=92218
Other than an aftermarket ECU the best thing to do is make sure your engine is running as efficient as possible, ie new platinum plugs, new fuel filter and pump, new air filter, new O2 sensor, splitfire coil packs and drive 'off boost' whenever possible.
you could try X-Speed in o'connor. There is noone in rockingham, only ford/holden specialists... and I wouldn't trust them to even know what a Stagea is lol
You could try GTi Performance too in Bibra Lake...ask for Simon, I'm not sure if he does SAFC's though. He is a nice guy and owns an S15 or two lol
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
