  • Replies 144
Not a car plate thing, but here's me and some friends standing in front of the fountain that was featured in the Matrix (think of the Woman in the Red Dress).
L33tness.
Less l33tness, but in the right job.
maybe lame... i just really hope its fast! i admire fast cars, no matter what manufacturer they're from. genuine fast car with plate to back it up... cool! otherwise.................. :)
Originally posted by Mick Trainer
It's only lame cause it targets our cars.  I'd like to take a shot at it.  Not that there are not very fast supra's around.  Nigels ran an 10.9 pass.
These plates are also cop magnets (not that it matter they target us so much now already) but also when studies have been conducted into eyewitness statements and their acuracy the only thing that has shown up time and again is if the car used had a personalised number plate it is remembered. Just a side note.
Mick.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
