they are H1, u will need 1 for each light .. just open the bonnect look behind the light .. its very easy once u see it... twist the cover open.. play around with the clip that holds it there ... you'll know when u see it .. and those blue xenons i don't think are blue at all .. just white .. they turn less white after a while of use ..
hope that helps
Get Philips or Osram. Both brands sell very good quality blue and white bulbs. Most of the other "blue" brands produce the wrong kind of blue (there are exceptions but I don't know of them). I am going to get some Philips white bulbs myself. They're only $80 for 4, but I am holding off until I get my tax refund. My insurance came in and it hurts :P
Narva bulbs are over-powered to get their brightness and as such tend to fail early.
well from what i know pretty much everything out there is pretty shit .. there is one brand called ... damn i can't remember ...oh yeah its PIAZZ ... its what u find in BMW and all them $$$ cars stock ... they are the whitest and brightest u will ever see ... but i think it costs like 150 a pair ... my cousin had them on his R33 and they looked the goods ... but if u can't afford them ... well just do what i do and get whatever cause you're goign to be replacing them heaps heheehe ... just don't get any grease on the bulb or u will be replacing them even more ... :mad:
The only place that used to sell them was a place in melb that closed down.... they were like $150 a pair but were marked up heaps. I got mine for like 70 bucks a pair from Hong Kong. There must be someone around in Aust (even a mail order place) that can get them for under a hundred bucks
The Philips Vision Plus I want to get are $40 a pair from Autobarn. I think Covingtons might be a bit cheaper, I will check there before I buy. I think the blue ones are in the same price range.
Hippy, I don't think they're illegal, but ask the shop guys. If you don't want to take their word then maybe ask the RTA, or just ask the cop when he pulls you over :D
Kdawgboostin33, I wouldn't bother changing the parkers. Why would you want to?
Hi Guys, though i'd post up some pics, theres hardly any difference looking at my crudy photos, but I have to say it really makes a difference when driving, i'd estimate about 30% better.
These are Philips Vison Plus ($39 from Autobarn) they were actually the cheapest ones they had. They have blue tips, but there is no blue element visible both when driving and looking at them from different angles with the naked eye.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
