I've started a new job recently which will mean when I'm fully trained I'll have to start at 1.30am. Meaning I have to leave my car alone in a shopping mall car park from 1.30am till 10.30am.
I have a Viper alarm system with immobilizer installed, and it's fully insured, but is there any extra security I can personally do? I heard someone saying they pulled their throttle plug when leaving their car in dodgy places. Is there a fuse or something simple that I can remove and replace easily that will stop the car from moving with doing damage?
Maybe I'm just being paranoid, as it's not a very valuable car to begin with, with quite a serious alarm system installed, but after reading all these theft articles I am a little concerned.
Thanks.
https://www.sau.com.au/forums/topic/206433-extra-security/
try one of those steering wheel locks that needs a key to undo
or put a chain or something through your wheel? just like a bike lock but bigger?
if your working in the shop near where its parked wont you hear your alarm?
if you do, just put your security training to good use
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3652847
All these security measures are good. But still dont stop people from trying... a smashed window and a FUBARed dash is going to be nearly as painful as losing the car.
I know you probably dont want to hear this but a good idea would be leaving the sky at home and trying to find another way to get there. Which i know would be hard since u start at 1.30am... Maybe a cheapo car that u use to work and home only?
or unless since u working at the mall when its shut... park it inside the mall! . that way its locked up... haha it may be a long shot but who knows?
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3652899
i used to work security in a couple of shopping centres. most usually have at least a few carparks that are on camera. maybe find out where they would be at the centre u work at and park there. if the security guys there are ok to just ask them to keep an eye out for u when they patrol. i used to get those kinda requests all the time so i did. i mean it may not work for u but as i said its worth a try
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3657284
Some funny ideas reading this lol, if some1 wants ur car, tints, steering wheel locks and depending on how gud thief is some alarms are all useless. Best wud be a fill switch or 2, not to hard to put in, chuck it in fuse box under bonnet. Iv heard alot of things bout how cars a stolen etc, stil cant believe how to some ppl its so easy. Dont waste money on any locks or nething from autobarn etc, get kill switch or fuel cut, or another car lol
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3682757
park under a bright light. when u leave, pop the boot and rip out the fuel pump or ign fuses.
REMOVE any precous objects from the car, dont give them an excuse to even think about it.
make sure that the alarm warning light is visible to all to see.
and finally, turn the volume and shock sensor up to MAX.. and u "might" be ok
Edited by r33cruiser
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3689748
Excuse my ignorance, but what is a fuel cut and a kill switch? Are they just switches hidden in your car that must be flicked on for the car to run? Can you buy them and install them, or is it just a custom wiring job you do yourself?
Also, how much would one of these cost to install?
Thanks.
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3691280
kill switch is like a master switch, its not an off on flick switch its like a pin with out the pin switch wont work, and depending how you wire it ie, you can use it as a fuel cut switch etc. some race cars have these, incase of accident or something they can pull the pin and then bang engine not goin no more lol switch isnt much cheep autotechnica one it around $10-$20 from memory and a beter bosch one is $30-$60
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3691306
Doesnt matter how much u spend on security, its not going to stop someone trying to steal it.
People steal any cars these days. Skylines to poor people are a wet dream... full of goodies
My advice is if you have to leave your skyline out of sight for even 30mins, you should be expecting the worse.
Buy a shit heap and drive that to work.
Edited by Antone
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3691637
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
