Hey guys,
I am going to change radiator and hoses this upcoming weekend. Ive search thru the forums but i am unable to locate a picture of the drain plug which is apparently on the passenger side of the engine block somewhere near dump pipes?
If someone could supply a picture... that would be alot appreciated. My car is a R33 GTS T. Also can someone explain to me about this heater on full to fully drain the system?
Cheers,
Brendan
https://www.sau.com.au/forums/topic/206435-coolant-flush-for-r33/
Hey mate, i did this today. Jack your car up first, makes it much easier. I really wish I had a jack... On the passenger side, there is a 40mm hole in the cover, which you can see a plastic bung through. Grab your screw driver and undo this. If you leave your radiator cap off, only some coolant will drip off, then take the cap off later when you are out of the way. Make sure the heater is open so the coolant in the heater can be drained an be replaced. Otherwise you won't flush all the old coolant out. I don't have a photo, but its pretty easy to find. Good luck!
So its just a plastic bung? i would of thought it mite be a taperd screw of some sort? .. wouldnt it fall out to easy if it was plastic ? .. would N/A be different to Turbo?
in regards to bleeding the system i heard u just turn on the car for a bit with the cap off and the air will bubble out. THen you just keep topping up...
Or have you got a different method?
Thanks for all your help NA_goodness i really owe u on this one.
oh and btw if i leave the heater on wouldnt it flatten my battery?
Edited by br3ndan
Ensure car heater is on hot (not fan, this ensures that the water in the heater coil is exchanged over aswell)
Remove radiator cap (vaccum will slow the drain considerably)
At bottom of radiator theres a plug, unscrew and drain water from radiator, hoses, and head.
Underneath exhaust manifold, at bottom of block theres also a plug, unscrew and drain water from block.
Pull radiator out, flip upside down and flush with garden hose, drain and refit and plug
Flush block with garden hose, drain, refit plug
Fill cooling system with premix inhibitor, or mix concentrate solution with demineralised water
Fit radiator cap, ensure overflow bottle is full, start car until warm
At the top of the plenum theres a radiator drain plug (You can also use temp sender). Remove and wait until water starts pouring out and refit.
Stop car, top up overflow bottle and radiator if needed.
Edited by Jmaac
Seems like a lot of work, at work we just use a hose to flush it all out. Too much effort to take the radiator out and muck around with that. If you use tap water in the cooling system, it will corrode your radiator, but just cleaning it should be fine, but its up to you how you do it. Bleeding the system is pretty much just running it for a while, letting the air bubbles escape. When it starts to overflow, i usually put my hand over it to make it go into the overflow tank and dont waste it. If your in a hurry, you can over fill the overflow tank, and it'll suck the coolant in as it is needed, but it probs isnt recommended.
thanks alot guys, i will be doing this on sunday... i will take photo as i go so we can make kinda a DIY on this. =)
As for the raditor.. doesnt really matter im going to take it off anyway... got a brand new twin core alloy one. =D .*drooool*
Edited by br3ndan
If u have a stock ecu it may run funny :/ you'll have to alter the temperature tables/conversion factors in the ecu to get it running nice and smooth i.e. poor cold starts, runs richer etc. Thats only if the cooling capacity (capacity to cool, not water volume) is increased and normal operating temperatures are reduced
Just make sure you bleed all the air out of the head. No amount of water will fill the cooling system if theres a big air bubble sitting up in there.
If your feeling really handy you could just scale the signal from the temperature sender with a few electronics
Ill scan the RBxx instructions and get them up for u
Edited by Jmaac
  • 1 month later...
The water in my car has gone all rusty since the last owner never bothered to put coolant in it, any idea if there is any special stuff to do a real good job of cleaning it out?
also anyone know how many litres the cooling system holds?
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
