Hey guys,
I am going to change radiator and hoses this upcoming weekend. Ive search thru the forums but i am unable to locate a picture of the drain plug which is apparently on the passenger side of the engine block somewhere near dump pipes?
If someone could supply a picture... that would be alot appreciated. My car is a R33 GTS T. Also can someone explain to me about this heater on full to fully drain the system?
Cheers,
Brendan
https://www.sau.com.au/forums/topic/206435-coolant-flush-for-r33/
Hey mate, i did this today. Jack your car up first, makes it much easier. I really wish I had a jack... On the passenger side, there is a 40mm hole in the cover, which you can see a plastic bung through. Grab your screw driver and undo this. If you leave your radiator cap off, only some coolant will drip off, then take the cap off later when you are out of the way. Make sure the heater is open so the coolant in the heater can be drained an be replaced. Otherwise you won't flush all the old coolant out. I don't have a photo, but its pretty easy to find. Good luck!
So its just a plastic bung? i would of thought it mite be a taperd screw of some sort? .. wouldnt it fall out to easy if it was plastic ? .. would N/A be different to Turbo?
in regards to bleeding the system i heard u just turn on the car for a bit with the cap off and the air will bubble out. THen you just keep topping up...
Or have you got a different method?
Thanks for all your help NA_goodness i really owe u on this one.
oh and btw if i leave the heater on wouldnt it flatten my battery?
Edited by br3ndan
Ensure car heater is on hot (not fan, this ensures that the water in the heater coil is exchanged over aswell)
Remove radiator cap (vaccum will slow the drain considerably)
At bottom of radiator theres a plug, unscrew and drain water from radiator, hoses, and head.
Underneath exhaust manifold, at bottom of block theres also a plug, unscrew and drain water from block.
Pull radiator out, flip upside down and flush with garden hose, drain and refit and plug
Flush block with garden hose, drain, refit plug
Fill cooling system with premix inhibitor, or mix concentrate solution with demineralised water
Fit radiator cap, ensure overflow bottle is full, start car until warm
At the top of the plenum theres a radiator drain plug (You can also use temp sender). Remove and wait until water starts pouring out and refit.
Stop car, top up overflow bottle and radiator if needed.
Edited by Jmaac
Seems like a lot of work, at work we just use a hose to flush it all out. Too much effort to take the radiator out and muck around with that. If you use tap water in the cooling system, it will corrode your radiator, but just cleaning it should be fine, but its up to you how you do it. Bleeding the system is pretty much just running it for a while, letting the air bubbles escape. When it starts to overflow, i usually put my hand over it to make it go into the overflow tank and dont waste it. If your in a hurry, you can over fill the overflow tank, and it'll suck the coolant in as it is needed, but it probs isnt recommended.
thanks alot guys, i will be doing this on sunday... i will take photo as i go so we can make kinda a DIY on this. =)
As for the raditor.. doesnt really matter im going to take it off anyway... got a brand new twin core alloy one. =D .*drooool*
Edited by br3ndan
If u have a stock ecu it may run funny :/ you'll have to alter the temperature tables/conversion factors in the ecu to get it running nice and smooth i.e. poor cold starts, runs richer etc. Thats only if the cooling capacity (capacity to cool, not water volume) is increased and normal operating temperatures are reduced
Just make sure you bleed all the air out of the head. No amount of water will fill the cooling system if theres a big air bubble sitting up in there.
If your feeling really handy you could just scale the signal from the temperature sender with a few electronics
Ill scan the RBxx instructions and get them up for u
Edited by Jmaac
  • 1 month later...
The water in my car has gone all rusty since the last owner never bothered to put coolant in it, any idea if there is any special stuff to do a real good job of cleaning it out?
also anyone know how many litres the cooling system holds?
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
