Hey guys,
I am going to change radiator and hoses this upcoming weekend. Ive search thru the forums but i am unable to locate a picture of the drain plug which is apparently on the passenger side of the engine block somewhere near dump pipes?
If someone could supply a picture... that would be alot appreciated. My car is a R33 GTS T. Also can someone explain to me about this heater on full to fully drain the system?
Cheers,
Brendan
https://www.sau.com.au/forums/topic/206435-coolant-flush-for-r33/
Hey mate, i did this today. Jack your car up first, makes it much easier. I really wish I had a jack... On the passenger side, there is a 40mm hole in the cover, which you can see a plastic bung through. Grab your screw driver and undo this. If you leave your radiator cap off, only some coolant will drip off, then take the cap off later when you are out of the way. Make sure the heater is open so the coolant in the heater can be drained an be replaced. Otherwise you won't flush all the old coolant out. I don't have a photo, but its pretty easy to find. Good luck!
So its just a plastic bung? i would of thought it mite be a taperd screw of some sort? .. wouldnt it fall out to easy if it was plastic ? .. would N/A be different to Turbo?
in regards to bleeding the system i heard u just turn on the car for a bit with the cap off and the air will bubble out. THen you just keep topping up...
Or have you got a different method?
Thanks for all your help NA_goodness i really owe u on this one.
oh and btw if i leave the heater on wouldnt it flatten my battery?
Edited by br3ndan
Ensure car heater is on hot (not fan, this ensures that the water in the heater coil is exchanged over aswell)
Remove radiator cap (vaccum will slow the drain considerably)
At bottom of radiator theres a plug, unscrew and drain water from radiator, hoses, and head.
Underneath exhaust manifold, at bottom of block theres also a plug, unscrew and drain water from block.
Pull radiator out, flip upside down and flush with garden hose, drain and refit and plug
Flush block with garden hose, drain, refit plug
Fill cooling system with premix inhibitor, or mix concentrate solution with demineralised water
Fit radiator cap, ensure overflow bottle is full, start car until warm
At the top of the plenum theres a radiator drain plug (You can also use temp sender). Remove and wait until water starts pouring out and refit.
Stop car, top up overflow bottle and radiator if needed.
Edited by Jmaac
Seems like a lot of work, at work we just use a hose to flush it all out. Too much effort to take the radiator out and muck around with that. If you use tap water in the cooling system, it will corrode your radiator, but just cleaning it should be fine, but its up to you how you do it. Bleeding the system is pretty much just running it for a while, letting the air bubbles escape. When it starts to overflow, i usually put my hand over it to make it go into the overflow tank and dont waste it. If your in a hurry, you can over fill the overflow tank, and it'll suck the coolant in as it is needed, but it probs isnt recommended.
thanks alot guys, i will be doing this on sunday... i will take photo as i go so we can make kinda a DIY on this. =)
As for the raditor.. doesnt really matter im going to take it off anyway... got a brand new twin core alloy one. =D .*drooool*
Edited by br3ndan
If u have a stock ecu it may run funny :/ you'll have to alter the temperature tables/conversion factors in the ecu to get it running nice and smooth i.e. poor cold starts, runs richer etc. Thats only if the cooling capacity (capacity to cool, not water volume) is increased and normal operating temperatures are reduced
Just make sure you bleed all the air out of the head. No amount of water will fill the cooling system if theres a big air bubble sitting up in there.
If your feeling really handy you could just scale the signal from the temperature sender with a few electronics
Ill scan the RBxx instructions and get them up for u
Edited by Jmaac
  • 1 month later...
The water in my car has gone all rusty since the last owner never bothered to put coolant in it, any idea if there is any special stuff to do a real good job of cleaning it out?
also anyone know how many litres the cooling system holds?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
