Anyone know how many different coil packs are avaiable for Series 1 RB25DET engines. According to Nissan the coil pack part # in my RB in a R31 are out of a CA16-18. The harness is factory and untouched but it has different plugs to all the other RB's I have seen. It has Z32 style coil pack plugs. Confused. :whistling:
https://www.sau.com.au/forums/topic/206534-rb25det-coil-packs/
According to Nissan, your R31 probably had a "red top" RB20DET in it. If the engine has been changed from "factory", it is a total waste of everyone's time asking for coil packs for a R31. You need to ask for coil packs for a Series I RB25DET.
Then again, if the engine is using the coil packs and loom from the "red top" ...
There is one type.
Two types for the RB25 (R33, SI and SII)
Just get a new loom (120-150) and the right coils :D
I know that Series 1 & Series 2 are internally different, but both still use the same coil pack plug. Why would I change the harness when there is nothing wrong with it? I just want to know why mine are different. :banana:
I am aware that the R31 had a BR20DET, I just mentioned that it was in an R31. I AM asking about RB25DET coil packs. The guy that had it before fitted the RB25, he used the entire RB25 engine loom. That's why I am confused :banana:
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
