Motorplex meet.
  • Replies 233
I've got a blitz dual SBC spec S. Low is 0.6bar and high is 0.8bar, been tuned by one of the best in the business (imho) and I havent had any detonation or pinging, but its also a lot colder than summer, so I'll be reverting to 0.6bar (I think stock is 0.5bar anyway) when summer rolls around and when I can afford it I'll pop in a front mount i/c
Nope, I'm tired of people argueing about who the best tuning shops are and who are crap and use sub standard methods, plus I dont like naming names as a couple of years ago I almost got taken to court for a post on hotcopper.com about the company I was working for. My suggestion is look at what projects they have built or had a hand in.
Rob
Originally posted by rob77
I've been to 3 tuning places and I'm very happy with this one.
Rob
Rob
Not that it matters to me cos I have my own favourites , but you can't get into trouble for recommending someone, only if you bag them without just cause.
IMHO I'm sure the tuner would be happy for the free plug as most times all you hear is how bad someone is, not how happy you are.
Ken
also might add to the list of places to try
i've been to;
psi
cypher
formaz
and xspeed
have heard of
barry's automotive
performance turbos
west racing
and a couple others i can't remember
in the end it comes down your personal experience at a place. a name want hurt.
ps for your 1/4 time on those boost levels low to mid 14sec passes with your mods
Count me in, so long as its fine and cold. Just had a boost controller put in and I want to improve on my 14.82 I set last-time (completely stock, cept for a 3.25" cat back system). I'm hoping for a very low 14 or high 13 with the extra boost.
Rob
Hmm I can't see you getting 13s with cat back and a bit of boost.
My first run was 14.5 - that was with just cat-back and pod filter.
now i have full turbo back exhaust with hi flow cat and 10psi (.7bar)
I am still not sure if i will hit 13s or not....... probably depend on the conditions ie how slippery the track is and how cool the air is.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
