Motorplex meet.
  • Replies 233
how hard was that to fit? I know someone on this forum is interested in the kit, but ill end up having to help him fit it, not naming any names.
Id like to know what im getting myself into if i agree to help.
Some people have no skills... you know who you are.
well, it took my mate about 30 mins to do one side and then he worked out the easy way and it took like 15 mins to do the other side. I'm one of those people that doesnt know a great deal about what I'm doing (plus I dont have the tools he has). Anyway, took about 45 mins or so all up. Its quite straight forward, if you want some help let me know as I know exactly how it hooks up. Been driving around a bit tonight and it seems to axel hop (I think) when driving straight and putting the foot down. Took a sharp left hand corner and I really had to try hard to get the tail out, very scary ****, so its definately holding the road better, next would be the coil-overs if you want serious all round handling, but my cars primarily for the drags and straight line power. I think I'm also getting a little bit of detonation running 0.8bar, either that or something is loose in my engine bay and making a rattling noise... might have to go back to 0.6bar *sigh* anyway, I'll run it down the drags on 0.8bar and see if I can get into the 13's, then start saving for a big **** off money style front mount cooler :D
Rob
Rob,
Thats pinging alright, if the 'rattle noise' is whilst under load.
Axle hop wise it might pay to have a look at some springs for the back/front. In terms of spring rate I would try to leave the front alone, and just pop in some stiffer units in the back.
Give a couple of suspension joints a call and ask them if what spring rate at the back will fix the axle hop. Once you find out the concensus on rate and height find out which brand of spring offers the cheapest solution. Kings/Pedders/k-mac blah blah blah are all made well enough, the rate and height are the important things. Change the shocks only when they are buggered (once again save the money), the stock rear shocks will have a nice long 'travel' which is what you need for the back.
Once you get it sorted you can post the rear rate for all the R33 boys and girls.
OK people I have looked into my crystal ball and it seems Sunday is going to be cool but fine and sunny....then again maybe a few clouds but definately no rain :P
So what time does the 'plex open the gates, how much to run and do we want to meet somewhere on the way down or just see each other inside?
I've just got my helmet orgainsed and have my fingers crossed the clutch stands up.
Cheers,
Ryan.
P.S. The above Weather forecast is not guaranteed;)
12psi
perfect launch w 20psi tyres
the damn standard turbo runs out of guts half way down the track thats the problem you need that 2nd gear pull all the way thru third it is a great gear just needs to be unleased by new turbo and intercooler
But then again anything is possible
Dont forget u can get a worse time when u dump it with higher boost more wheel spin for longer
Well, definately getting pinging on 0.8bar of boost, not all the time probably only about 1% of the time I floor it, but still it isnt good. So I'll coax it down the 1/4 with a good top up of octane booster and see if I can break a high 13, but I wont be pushing too hard. Might have to find a front mount quick :P
Rob
Well you never know B1 do a few runs and find out :-) a good 60ft time is the key i guess..(u sure Skyzerr was running only 10)
The car actually runs wuite smooth and has a decent power range, But thanks for the encouragement :lol:
Adam a mouse could run in and out of those T04 blades at 8psi while you race all the way down da track
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
