Just a heads up for anybody putting in Sard injectors.
I just finished fitting 550cc side feeds to the skyline, and incurred a few dramas.
the main problem was that the o-ring supplied on the injector was too small and leaked fuel when the ignition was switched on. It didnt actually leak out, it bloody poored out almost to the point of spraying!
Lessons learned.
1/ Make sure you pressurise the fuel rail before replacing the throttle body (stock plenum) as it is still possible to remove and check the injectors with just the fuel rail in place. (unfortunately I was under the impression that as I had purchased the injectors and collars from sard new - that all would be ok.
2/ Remove the sard o-rings and use the stock injector o-rings. They are alot fatter than the sard ones and they seal!
3/ To remove the stock injectors from the rail, if you twist the injector to free it a bit, then spray crc or similar - they still dont come out very easily. I ended up just tapping the pintle with a hammer and out they popped. Either that or be prepared to get really frustrated.
4/ It is so much easier to just pay someone else the $200 odd that it would have cost to get the job done.:mad:
5/ The power fc % correction for injectors works pretty bloody well:D Started up straight away, no smoke out the exhaust.
Hope this may be of help to anybody else thinking of doing these themselves.
https://www.sau.com.au/forums/topic/20683-sard-injectors-in-at-last/
  • Replies 42
Mine were a bit under 1K from greenline. Probably a bit cheaper now that the AUD is a bit stronger.
The injectors themselves flow really well, all less than 1% difference - I had them flow tested prior to fitting. In fact 5 were bloody close to identical flow, and one was just a poofteenth lower (0.5ml per 100ml on open flow)
INASNT, no I didnt hear, poor bugger, hope he is ok. Your order should be ok, as he passes the orders on to japan as soon as he gets them, if you are unsure, just contact the japan office.
MattR - I was really impressed by the flow of the injectors, so was the guy who did the testing. Am still waiting to get them tuned. It would have been so much easier if they fitted first time is all, or if I had a front facing plenum. Also, must admit I was a little dissapointed that the o-rings they supplied didnt fit properly.
From all accounts they are good injectors, and they arent hurting your figures any:D Just hope when all is fitted, I might be making similar power - only time will tell.
Hey guys, I've just got a set of Sard injectors for my GTR from greenline and they didn't come with o-rings at all.
Steve, you said you used the standard o-rings instead of the Sard ones as they are better?? I have bought a set of standard nissan o-rings which should fit the Sards as you guys have said. Maybe the side feed injectors come with the o-rings and the top feeds don't?
Anyway fingers crossed the standard ones fit the sards...
BTW who can flow test the injectors?
Cheers
Brett
The o-rings did come with the ones I got. The bottom o-ring, near the pintle fitted fine, it was just the top one that is supposed to seal between the collar and the fuel rail that was too thin. O-rings arent very expensive, only a couple of dollars each, but if you can fit the stockers, save a few dollars anyways.
If you find a fuel injection specialist they should be able to flow the injectors for you.
Thanks for the offer Dean, probably take you up on that one:) Hoping around the 300 mark at this stage - similar to MattR's. Depends on how well the turbo goes (a HKS 3037S 56T) and how the bottom end holds up. I have a few other plans too, which will include a bigger turbo, but they are way off at the moment.
N/A® I got them done by a place on little Rundle street, cant remember the name off the top of my head, got it written down somewhere.
they quoted me $5.50 per injector, but it ended up costing a bit more (55.00) as they had to set up the machine for them (apparently there are dozens of differnet size/shape side feed injectors) then they had to pulse them for some time as the initial tests flowed 5% apart, which they werent happy with. He put this down to being new, and sure enough when they had been run for about 20 mins, they came up almost all exactly the same, just under 1% out on one injector, and a poofteenth out on two of the others.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
