  • Replies 112
So it's Friday arvo nearly time to knock off and I was bored as hell so I went through the thread and compiled everyone into an easy to read list.
SAU ID PSN ID
Sl!m - VertexR32
Gts30t - Shodaddy
mattis96 - qik33
trism - t_r_i_s_m
r33cruiser - a_BFG
smurf80 - smurf80
MADGT4 - madsammy
OZ_Pomy - iLEC
Kozeyekan - Kozeyekan
thirty four - reggin_au
Goziiraaa!! - Bourne01
[Michael] - kaido
GoldZilla - GoldZilla
kralster - MrCharismaAUS
Magic - Blaq-Magic
typevu - typevu
Bumblebee- GT2-KLR
GeeTR - rkaid
S13Deviat - Andominated
YLD-CHLD - YLDCHLD
Krimz - krimzn
=premo= - incorrect_method
LEANBAC - LEANBAC
dezz - dezzmang
AMS - oconnorams
Dush - Dush
MaTBoY - matboy
atang - atang34
TiTAN - sau-TITAN
SKYLVIA - WildWarriorBizz
Kaz180 - Kaz180
ABuSD - KellyNUTS
krzysiu - KrzysiuR33
BAMR33 - bamr33
gt_relish - Gonzarelli
Frunknmont- fl1pp3
PSICO - McWhizzle
PWND - foamer
joe26f - Stagezilla
jeffboyracer -sjhanan
bigjimmystyle- Bigjimmystyle85
W0rp3D -warped
EVL-R33 -WarMachine
writeoff -writeoff3
muirsky -muirsk
hkspwr -hkspwr115
Ry34 - Ry34
omy-33 ashdroid
TheProDaniel- TheProDaniel69
Howie -Howiefied
hanyou -hanyou8
nismo_GTS -Ants84
Sl!m if you want seeing as you are a mod and the thread starter you can put this in the first post.
Edited by Frunknmont
  • 1 month later...
  • 1 month later...
Good work on the list Adam!
I'm still playing COD4 but am SICK of getting shafted because of the lag. I'll try coordinate a time for a SAU grudge match. Look for invitations in your inbox.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
