  • Replies 112
So it's Friday arvo nearly time to knock off and I was bored as hell so I went through the thread and compiled everyone into an easy to read list.
SAU ID PSN ID
Sl!m - VertexR32
Gts30t - Shodaddy
mattis96 - qik33
trism - t_r_i_s_m
r33cruiser - a_BFG
smurf80 - smurf80
MADGT4 - madsammy
OZ_Pomy - iLEC
Kozeyekan - Kozeyekan
thirty four - reggin_au
Goziiraaa!! - Bourne01
[Michael] - kaido
GoldZilla - GoldZilla
kralster - MrCharismaAUS
Magic - Blaq-Magic
typevu - typevu
Bumblebee- GT2-KLR
GeeTR - rkaid
S13Deviat - Andominated
YLD-CHLD - YLDCHLD
Krimz - krimzn
=premo= - incorrect_method
LEANBAC - LEANBAC
dezz - dezzmang
AMS - oconnorams
Dush - Dush
MaTBoY - matboy
atang - atang34
TiTAN - sau-TITAN
SKYLVIA - WildWarriorBizz
Kaz180 - Kaz180
ABuSD - KellyNUTS
krzysiu - KrzysiuR33
BAMR33 - bamr33
gt_relish - Gonzarelli
Frunknmont- fl1pp3
PSICO - McWhizzle
PWND - foamer
joe26f - Stagezilla
jeffboyracer -sjhanan
bigjimmystyle- Bigjimmystyle85
W0rp3D -warped
EVL-R33 -WarMachine
writeoff -writeoff3
muirsky -muirsk
hkspwr -hkspwr115
Ry34 - Ry34
omy-33 ashdroid
TheProDaniel- TheProDaniel69
Howie -Howiefied
hanyou -hanyou8
nismo_GTS -Ants84
Sl!m if you want seeing as you are a mod and the thread starter you can put this in the first post.
Edited by Frunknmont
  • 1 month later...
  • 1 month later...
Good work on the list Adam!
I'm still playing COD4 but am SICK of getting shafted because of the lag. I'll try coordinate a time for a SAU grudge match. Look for invitations in your inbox.
