  • Replies 112
So it's Friday arvo nearly time to knock off and I was bored as hell so I went through the thread and compiled everyone into an easy to read list.
SAU ID PSN ID
Sl!m - VertexR32
Gts30t - Shodaddy
mattis96 - qik33
trism - t_r_i_s_m
r33cruiser - a_BFG
smurf80 - smurf80
MADGT4 - madsammy
OZ_Pomy - iLEC
Kozeyekan - Kozeyekan
thirty four - reggin_au
Goziiraaa!! - Bourne01
[Michael] - kaido
GoldZilla - GoldZilla
kralster - MrCharismaAUS
Magic - Blaq-Magic
typevu - typevu
Bumblebee- GT2-KLR
GeeTR - rkaid
S13Deviat - Andominated
YLD-CHLD - YLDCHLD
Krimz - krimzn
=premo= - incorrect_method
LEANBAC - LEANBAC
dezz - dezzmang
AMS - oconnorams
Dush - Dush
MaTBoY - matboy
atang - atang34
TiTAN - sau-TITAN
SKYLVIA - WildWarriorBizz
Kaz180 - Kaz180
ABuSD - KellyNUTS
krzysiu - KrzysiuR33
BAMR33 - bamr33
gt_relish - Gonzarelli
Frunknmont- fl1pp3
PSICO - McWhizzle
PWND - foamer
joe26f - Stagezilla
jeffboyracer -sjhanan
bigjimmystyle- Bigjimmystyle85
W0rp3D -warped
EVL-R33 -WarMachine
writeoff -writeoff3
muirsky -muirsk
hkspwr -hkspwr115
Ry34 - Ry34
omy-33 ashdroid
TheProDaniel- TheProDaniel69
Howie -Howiefied
hanyou -hanyou8
nismo_GTS -Ants84
Sl!m if you want seeing as you are a mod and the thread starter you can put this in the first post.
Edited by Frunknmont
  • 1 month later...
  • 1 month later...
Good work on the list Adam!
I'm still playing COD4 but am SICK of getting shafted because of the lag. I'll try coordinate a time for a SAU grudge match. Look for invitations in your inbox.
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
