Radiator Air Deflectors, New Group Buy (no 5)
  • Replies 113
Hi Ppls,
Sorry for the long time in getting this going, but there is light at the end of the tunnel.
I'm off to NZ next week, but when I return I'm all geared up to churn out some panels.
I haven't comfirmed pricing with my manufacturers of the ally (steel is going up rapidly) but I don't expect a huge increase, maybe a few dollars.
We'll see.
Bare with me and all will be well.
Cheers
Pete
I would like one for an R33 GTST Series 2 in BLACK thankyou.
Do you have any ETA's to when you can carry out the order?
Thanks champ,
Paul.
Hi Gents,
I'm back from NZ this morning and will begin collating stuff for the order soon.
Thanks for your patience, the end is in sight!!
Cheers
Pete
hey i was wondering if i am too late for this group buy.
If not then count me in for a 33 GTST S1 no powdercoat thanks.
  • 3 weeks later...
Hi Guys,
I'm about to start in earnest.
Will get requote on material cost this week and see how we go.
Cheers
Pete
How much to have one fabbed up so that it fits a R34GTT with series one front bar... I want it extending all the way to the headights just like the GTR versions from Jap-land...
Can it be done, and most importantly, will you do it - premium price is not a problem (within reason of course)
Yeh im keen for a similar setup to this but for nismo bar.
