  • Replies 72
Hmmm there were ALOT of guys there....
I was like... :) i seen that car on the road!! lol
it was alright... but i couldnt believe how some of the girls
were so dressed up for a "meet".. lol i mistook them for the models!
funny you say this cause there was no trouble tonight?
So XESSIV didn't get pulled over by the cops on his way out, after bouncing his unloaded engine off the limiter inside the carpark? There weren't random other cars sitting their also free-revving their engines? There weren't guys trying to rip skids on the way out?
No-one really got busted by the cops this time, but they didn't last time either when people were doing burnouts in P6. It doesn't mean they weren't doing shit and acting like tools, which is the point I was making in the post you quoted.
theres nothing wrong with using import models/go-go dancers to attract car enthusiasts to meets. ppl like that, would you rather see YMCA boys instead?
Maybe I'm old fashioned, but I'd rather see cars at a car event and talk to fellow car enthusiasts at a social event. If I want to see tits, I'll go to the Cross.
If these people were actual car enthusiasts, other nice cars and the chance to talk to their owners would be attraction enough. SAU cruises get a good number of attendees, but its not because the organisers bring scantily clad girls to them.
Instead, you get random blow-ins that must have been neglected as children because they act out to get the attention they crave, giving the rest of us a bad name.
Edited by scathing
was a pretty good night but shit weather
R34 GTR was the toughest!!
gold S2K got booked by cops for ripping a burnout
Gold S2K Xe55IV did NOT get booked !
the cops just pulled him over and gave him a warning & make an xample so ppl will behave demself !
Couldnt agree more Alan.
Well said :laugh:
I didnt bother going, started raining and I figured getting some would be a better idea.. so left it alone..
Was planning on going but $15 entry really dissed it for me.. wtf should I pay to show off my car they should pay me!
Hey... umm.. what fee?
I didnt pay anything when i went.
Oh i see...
I think you mustve been reading the part where the girls are going to be at
equilibrium hotel...
This is what it says...
"March 1 - GQ @ Equilibrium Hotel, Sydney"
$20 General Entry
$15 before 10:30pm
$15 all night if in the guestlist or birthday list
lol
oh wellz.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
