RB26DETT running a K&N Panel filter, full exhaust system, boost controller at 12psi and larger FMIC. Soon to have Apexi PFC.
will HKS 264 step 1 Exhaust Cam make much of a difference? Will not having an aftermarket inlet cam hinder it?
Cheers guys.
https://www.sau.com.au/forums/topic/207746-hks-264-step-1-exhaust-cam/
No point.
Turbos, ECU, boost, build motor before i'd even be thinking about cams, not high on the priority list
Cam Gears however ($150) offer a brilliant gain and return on investment with much better midrange
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
