Hey guys firstly hello, my name is Simon, i live down south and have just bought my first skyline! :D
Some of you may have know my last car 'DARE YA' the orange Magna, which i sold just over a week ago now!
So this is my new car and is just how i bought it.
Skyline R33 series 2 96'
RB25DET
90,000ks
Manual
208.3kw atw ..... oh and its on stock boost 8psi!
HKS 2540 large turbo
large front mount cooler
twin piped stainless dump pipe into 3inch exhaust into twin rear straight thru mufflers
Remapped ECU (Speedlabs Jeff)
Apexi Power intake
Bosch 040 fuel pump
LED tail lights
Lowered hard suspension
SSR professors 18inch 3 piece genuine 245f and 265r
400r bodykit
12inch percaso sound stream sub with pioneer 760w 2ch and pioneer hu and spreakers
really only looking at putting a dual stage boost controller on it as im pretty happy with the power its putting out atm
Well im hoping to catch up with some of you guys around the place and get to know a lot more about the turbo scene :D
cheers
Simon
https://www.sau.com.au/forums/topic/207924-new-member/
Welcome mate.
Can i ask what you ended up getting for your magna?? that was a HOT car...
SO will your skyline be turned into a show pony to???
lol
hey thanks guys,
ill have to have a look what time the dyno day is etc! ive sorta got the day off lol.
yeah i got a little less than i wanted but i took my plates and nos off! i got 16.5k
this car im trying not to touch too much but i know i wont be able to resist :D
https://www.sau.com.au/forums/topic/207924-new-member/#findComment-3677553
welcome mate, car loos clean as and good power too. Just a question, are those photos of car in current state, just cause that kit doesn't look like a 400r kit.
thanks, yeah thats it after a few hrs cleaning and polishing,
not too sure on the kit im just goin on what i was told from the seller lol
i thought that the rear was a nismo or something like that
https://www.sau.com.au/forums/topic/207924-new-member/#findComment-3677881
haha hi Simon. So ur the one thats been going past my place in the silver skyline. I live just out on elizabeth rd, just down from ur mate that owns the little maroon lancer with the grey front bar, guessing he is a friend. Seen ya go past monday night and sunday arvo i think it waz. Ya car sounds and looks awsome :D
https://www.sau.com.au/forums/topic/207924-new-member/#findComment-3678250
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
