Engine Performance Problem
Guest McRen
Hi,
Recently my car has been misfiring at 5000 RPM, I own an R33 GTS-T.
I replaced the spark plugs using 1.05 mm gap. The car continued to misfire. I regapped the spark plugs to 0.8 mm and the misfire has gone.
The only problem now is when the engine hits 5000 RPM. Usually at this point you can feel a big power increase but there is none (the performance doesn't change). When the car hits around 6000 RPM you can feel more power but feels like it is hesitating...
The car is running standard computer and boost.
Any ideas?
https://www.sau.com.au/forums/topic/20797-engine-performance-problem/
Correct me if I'm wrong, but the variable valve timing will change your timing as you accelerate... I notice this in mine, and it's probably the power increase you're noticing in yours.
About 5000 rpm is where the stock boost solenoid kicks in... If you're not getting that extra boost then you might want to look at the solenoid (it's near your power steering fluid bottle). Check the air lines for cracks too.
Guest McRen
I looked at the boost guage and the car is coming onto full boost. Something feels restricted or maybe the car has retarded for some reason? Resetting the ECU gives a slight performance gain, but this is really weird.
On a few occasions the car has been fine reving out to 7000 RPM, but mostly is loosing power at 5000+ RPM.
I think I'm going to replace the injectors, fuel filter and clean the air flow meter...
i have an almost identical problem which occurs at 4500 and dissappears at 6000. between 6 and 7k rpm the power comes back on hard.
boost solenoid is plugged up.
AFM has been cleaned.
tested with another factory ecu
played with base timing
on the few times i have tested, if the car is hot and decent heatsoak has occured (eg stopped for 10min gettin fuel), it revs through without a problem. after another 10mins of normal driving though when things have cooled down a bit, problem is back again. the AFM might be reading too much (cool) air and overfueling to compensate.
If you get a chance McRen, please test this in your car.
cheers
Guest McRen
cheers
Crooser,
It鈥檚 good to hear I'm not alone on this one, not that I'm wishing other people had a similar problem. I'm not 100% sure what heat soak is, I'll assume from what you鈥檝e said this happens when the car has been turned off for 10mins after it was up to its normal temperature previously.
I'll try this today and let you know what happens. Now that I think about this I remember stopping at a newsagency for 10 mins or so and that was one of the occasions the car revved out properly afterwards.
Here are the things I've tried to rectify the problem.
* Changed spark plugs to 1.05mm
* Re-gapped spark plugs to 0.8mm
* Cleaned air flow meter (this was already clean, but I sprayed it with solvent anyway).
I'm going to change the fuel filter. I'll keep you posted tomorrow.
Guest McRen
I forgot to mention that I put half a bottle of injector clearner through the car. I just filled the car up full again after work today and the car feels like its starting to rev out more then it did before.
After 5000RPM it would hesitate. Now it still does a little after 5000RPM but not as much.
So I think its probably the injectors that need cleaning...
I think I'll put a whole bottle in next time I fill the car.
Does anyone know if you have to put injector cleaner in when the tank is empty?
Originally posted by McRen
Hi,
Recently my car has been misfiring at 5000 RPM, I own an Datsun 120Y.
Any ideas?
The points may have closed over.
You should also check the distributor cap for cracks.
    • HPA do an interesting video on tuning, and Adrian shows on the dyno, moving from 10:1 to 12:1 (And I think even 13:1) and the power moves SFA. However, a couple of degrees of timing has a HUGE impact. Exhaust side of things will more be the length of the exhaust and how many bends and turns you have. The straighter you can keep it, the better. By a lot. Oh, and getting the diameter right. Bigger isn't always better. Going to big can actually lose you power.
    • I have to say, most people I see on the road fit the bill of atrocious drivers. Whether they be cowboys in their dual cabs, bogans in the Commodores, or the soccer mums. Pretty much most people on the road put zero freaking thought into driving. Barely look further up the road then the end of their bonnet, and have never even thought about how catastrophically wrong shit can go, by doing what they all deem as normal driving. Especially their late braking, racing to stopped lights, and sitting half a foot off the bumper of the car in front at 110km/h. Wanna know what's even better? By the time their kids get to be old enough to learn to drive, they've already got in the back of their brain what is normal driving, how annoyed you're allowed to get at people etc, and then their parents who actually have zero freaking skill at driving (Even though they constantly say "I've been driving for 20 years and never had an accident!") teach the little twerps how to drive, or should I say, how to make a car move. Literally watched a parent teach their L Plater, on a 4 lane freeway, that you just slam the brakes on, and push your way over, even with a B Double bearing down on you, and that's how you should drive, rather then, just keep going to the next exit. Same shit happens all the time for side streets etc, watching numpties pull dumb shit turns pushing across 3 lanes of traffic, rather than just go up the road another 30 seconds, and take the next turn that'll get you to the same location... Oh, and the damn right lane bandits. Or the retards driving along with their headphones in, and can't hear the ambulance or fire truck right up their ass about to run them over...   Pretty much, people drive on the road, like ego centric f**ks, and don't actually think how dumb shit their driving is, how it could easily kill them or someone else in a split second, or at the very least, how they're driving is contributing to all the shit they're bitching about on the road, like shitty congestion!
    • Yeap, not as doorty as ITB's, but alot more doorty than before, induction sound great when I'm up it 馃
    • Any difference in induction noise?
    • I think you know exactly who I mean.
