hi guys,
any shops out there doing deals? tempe tyres are hard to beat on price...just wandering if there is anyone else out there with competitive prices.
im not after the best quality tyre out there, well put it this way i had nankangs in the past & i was happy with them.
i was quoted $190 each for kumho 265x35x18.
regards,
marko.
https://www.sau.com.au/forums/topic/207975-best-place-in-sydney-to-buy-tyres/
im more focused on cost rather than performance - great link though, thanks
This is the whole point of the thread.
People compare tyres & prices.. If you know the tyres in the size that you are looking for search the thread and people usually post the prices up as well..
eg:
Handco(k K104 sport "Y" rated (300km)
dry 9/10
wet 8.5/10
value A+++
great handling tyre cost $230 for a 255/40/17 From JAX!!
Am also interested as I am looking for a set of Falken 452 which are pretty much the best tyre in its price range.
Tempe has been cheapest so far but their service is terrible. Jobsons in Parra is not too far off, probably better service too haha
Anyone else have ideas?
what did tempe quote you for the falkens?
was thinking of buying one as well, same size 265 35 r18
i find falken zeix to be shithouse.
Found 2 in ebay.
Nankang
http://cgi.ebay.com.au/Brand-New-265-35-18...1QQcmdZViewItem
Federal
http://cgi.ebay.com.au/265-35-18-BRAND-NEW...1QQcmdZViewItem
5 bux diff on both. edit: no pick up, which sux ballzeh :)
Edited by GTL05T
Id rather pay more than use tempe again
I thought the same mate. I recently bought Falken FK452's in 265x18 .. Rang around everywhere ELSE but Tempe fearing their quality of service and got quoted as high as $415.
Called Tempe in the end, they said $260 straight up and the guy was actually not a dick about it. He was a normal guy and got back to me when he said he would.
If you want to talk to someone good at Tempe ask for Max he's the guy I dealt with and his service and price was good.
When i asked for a discount on that price he chucked in fitting and balancing... which is quite a good deal I reckon...
Don't write off Tempe imo...
Get these mate, i've got the them and for the price they're bloody awesome!!!
What are "THESE" mate?? Ill be up for a set in the next month or so too..... So i'm keen :yes:
Sorry to cut into the thread :)
What are "THESE" mate?? Ill be up for a set in the next month or so too..... So i'm keen :(
Sorry to cut into the thread :P
Antyre, it was in the bit I quoted.
Contact Greg from autosport at kirrawee 9521 1388
bloody awesome in comparison to what exactly? :)
they sound like cheap chinese tyres.. have you had any other tyres on your car?
I've had a couple of good experiences with Tempe, they've always been nice to deal with in the times that i've been there. Although they definitely dont fit the type of people I like to deal with, I've never had a negative experience there either. Just dont expect a coffee and cookies on arrival. They're business is wheels and tyres, they are the cheapest and they know it. The arrogance shows occasionally!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
