HI guys, I will be getting my HKS GT2835 Pro S soon, just wondering, for the people that have it, does it still have that nice spool jet sound that the standard turbo provides?
You'd think it would be louder since it's a bigger turbo, am I correct???
I would hate to have it installed and it makes minimal spool noise, Id be heart broken! lol :)
cheers
And what about the flutter, I love my flutter... Will the flutter be louder than the standard turbz? I should be, bigger turbo yeh?
I would suggest a Recirculating BOV, as it will make your turbo last longer.
Also, sounds like you want attention?
Cops will love you.
This one is better:
http://users.on.net/sau/pacey.avi
Port shrouded is a "windowed" compressor cover
Looks like this:
Lol, still dont get what you mean, that just looks like a normal turbo to be that dont have a filter and not connected to the cooler...
ps. your vid didnt work :)
Cops will love you.
F#$k recuirculating, I just wanna hear that biatch flutter.... Took of the plumb back stocky BOV, flutters real good.
So will the HKS GT2835 Pro S Flutter louder?
ANd also, will the HKS GT2835 Pro S turbz maker the spool sound yours did?
CHeers
spool will be louder than stock as the wheel is steel, your pushing much more air, and running a pod (no doubt)
all these things will make it a fair bit louder.
My old GT30 sounded like an aircraft once i plumbed the gate up :)
i've got a link for my vid somewhere, but you cant hear a lot over screamer pipes :)
This one is better:
Looks like this:
Im about to bolt on one of those,external gate though :)
CHeers
You dont want it to "flutter" your turbo wont last long.
lancers have mad flutterz and spool noise. Buy a lancer and its a straight fit for a triton diesel turbo to go on. Will be faster, be more cuztom, and flutter way more.
You dont deserve a nissan
Vid please! What were the specs of that motor?
ok... found it Click me!!!
GT30, 45mm gate, Nismo (factory GTS-R) manifold, RB25 (built), factory head/cams :down:
24psi/104 sunoco, thats the major stuff anyhow
GT3040?
Guest
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
