I'm getting ready to go look at a GTS-T R32 Type M. I'm not sure if the motor is worth it, cause it seems you have to put a lot of money into the engine to make some good numbers. Plus im going to have to take a big loan and have payments, so I wouldn't be able to do anything major soon.
https://www.sau.com.au/forums/topic/208067-rb20det-worth-it/
Well... any motor that you want to make more power - will cost money.
Whats the budget? If you cant afford to EASILY make repayments - you shouldn't be purchasing a skyline.
I don't understand what your getting at here really.
R32's are lighter and cheaper than R33's, hence RB20. R33's are more, hence heavier and RB25 come with them.
RB20/R32 isn't a bad car for what it is, but its aging, 15+ years now
Isnt it only about 50odd kg?
Stick with your Turbo Civic for now and keep saving. If your after speed, then the Civic will whoop the Skyline hands down.
Sae up, get a Skyline, model preffered, then spend some money on it. Could even buy a nana spec R32 and RB25 it? Im still relatively new so i dont know if thats an easy/cheap/worth it option. :down:
I haven't built my engine or anything thou. I'm only running bout 8psi. I raced one of my buddies wrx's and he is close to 280hp, and I stayed right with him. Idk I was wondering if I should wait for a skylline with the twin turbo. Insurance thou?
i rekon u would be disappointed with the r32 rb20. Id either keep saving for the gtr or get the r33 rb25 as its easier to get power out of than the rb20, unless ofcourse u like the look of the r32 like me
Sae up, get a Skyline, model preffered, then spend some money on it. Could even buy a nana spec R32 and RB25 it? Im still relatively new so i dont know if thats an easy/cheap/worth it option. :laugh:
Weight is R32 1260/80 (earlier 32's/later 32's) vs R33 1400+ so its around the 120 mark or a tad more. Dunno why everyone gets different specs but those are the ones from factory.
The civic is a light car, with an alrite motor, however as you say, an R32 with an RB25 in it would have a truckload more torque available at lower rpm than all honda engines (stock for stock). Even a 20 probably has more torque at lower RPM than most honda engines stock for stock. Id rather an R32 RB20DET than a honda but thats just my preferance...Horses for courses
Proof please..
show me the nissan factory information of the above weights?
I've always known it to be:
R32 early = 1290kg
R32 late = 1320kg
R33 gtst = 1370kg
According to Carizma
Curb weight for R32: 1480kg
http://carizma.com.au/Pages/Details%20-%20...e%20-%20R32.htm
Curb weight for R33: 1530kg
http://carizma.com.au/Pages/Details%20-%20...e%20-%20R33.htm
Doesn't sound right to me..
According to Autospeed R32: http://autospeed.com/cms/A_0853/article.html?popularArticle
This backs up what GTST said
The GTS-t is notably lighter than its AWD counterparts (1320kg versus up to 1480kg).
According to Autospeed R33: http://autospeed.com/cms/A_1105/article.html?popularArticle
On the road, the R33 GTS25T coupe's 1360kg kerb mass is apparent.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
