I'm getting ready to go look at a GTS-T R32 Type M. I'm not sure if the motor is worth it, cause it seems you have to put a lot of money into the engine to make some good numbers. Plus im going to have to take a big loan and have payments, so I wouldn't be able to do anything major soon.
https://www.sau.com.au/forums/topic/208067-rb20det-worth-it/
Well... any motor that you want to make more power - will cost money.
Whats the budget? If you cant afford to EASILY make repayments - you shouldn't be purchasing a skyline.
I don't understand what your getting at here really.
R32's are lighter and cheaper than R33's, hence RB20. R33's are more, hence heavier and RB25 come with them.
RB20/R32 isn't a bad car for what it is, but its aging, 15+ years now
Isnt it only about 50odd kg?
Stick with your Turbo Civic for now and keep saving. If your after speed, then the Civic will whoop the Skyline hands down.
Sae up, get a Skyline, model preffered, then spend some money on it. Could even buy a nana spec R32 and RB25 it? Im still relatively new so i dont know if thats an easy/cheap/worth it option. :down:
I haven't built my engine or anything thou. I'm only running bout 8psi. I raced one of my buddies wrx's and he is close to 280hp, and I stayed right with him. Idk I was wondering if I should wait for a skylline with the twin turbo. Insurance thou?
i rekon u would be disappointed with the r32 rb20. Id either keep saving for the gtr or get the r33 rb25 as its easier to get power out of than the rb20, unless ofcourse u like the look of the r32 like me
Sae up, get a Skyline, model preffered, then spend some money on it. Could even buy a nana spec R32 and RB25 it? Im still relatively new so i dont know if thats an easy/cheap/worth it option. :laugh:
Weight is R32 1260/80 (earlier 32's/later 32's) vs R33 1400+ so its around the 120 mark or a tad more. Dunno why everyone gets different specs but those are the ones from factory.
The civic is a light car, with an alrite motor, however as you say, an R32 with an RB25 in it would have a truckload more torque available at lower rpm than all honda engines (stock for stock). Even a 20 probably has more torque at lower RPM than most honda engines stock for stock. Id rather an R32 RB20DET than a honda but thats just my preferance...Horses for courses
Proof please..
show me the nissan factory information of the above weights?
I've always known it to be:
R32 early = 1290kg
R32 late = 1320kg
R33 gtst = 1370kg
According to Carizma
Curb weight for R32: 1480kg
http://carizma.com.au/Pages/Details%20-%20...e%20-%20R32.htm
Curb weight for R33: 1530kg
http://carizma.com.au/Pages/Details%20-%20...e%20-%20R33.htm
Doesn't sound right to me..
According to Autospeed R32: http://autospeed.com/cms/A_0853/article.html?popularArticle
This backs up what GTST said
The GTS-t is notably lighter than its AWD counterparts (1320kg versus up to 1480kg).
According to Autospeed R33: http://autospeed.com/cms/A_1105/article.html?popularArticle
On the road, the R33 GTS25T coupe's 1360kg kerb mass is apparent.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
