The transmission should be no trouble as it's just about the same as what comes in the 260RS anyway, however this specific car has previous accident repair history so it would not be suitable for import to Australia ... the price is not so cheap either.
We're the sole Victorian agent for trade car view. The 0 doesn't always mean accident on tradecarview, it just means that the dealer on tradecarview hasn't given their car a rating yet. Or, sometimes cars which are modified also get a 0 because they don't grade them. The B is the interior rating.
I'd imagine this car would be about 2 mil, not 3. I think they have both 5sp and 6sp, so as long as the gear box is factory, should be fine about that.
How much accident/repair history is too much?
If the compliance workshop stick to the laws then ANY accident repair history is too much although minor paint repairs should be allowed - with that said there are workshops who will reject cars with any paint repairs just to be safe (overly fussy!) and others who will pass almost anything as long as the car stays together in their workshop (very dodgy!) ... personally I would suggest keeping well clear of any cars with known accident repairs and check all cars well before buying as most sellers will say 'no accident history' by default unless you prove otherwise.
We have dealt with many sellers from TradeCarView and found that most are very dishonest about condition at the very least, many do not even own the cars they list for sale. Some sell on behalf which means that they are guessing the condition and can't check because the car is not in their yard.
I agree that some sellers are honest and will list cars as accident grade (like this car with grade 0A) when they are unsure either way but most will do the opposite and note no accident history (like grade 4) for all cars even when they know or suspect otherwise. What I am saying is that you should not buy a car, especially from a frequently unreliable source like TradeCarView, unless you can verify the condition from an independent source - it's even more critical when the seller lists the car as an accident grade like this one.
Keep in mind that TradeCarView is a place where sellers list cars targetted specifically at international customers, these are mostly end users who will only ever buy one car and by the time it arrives in Australia and you realise that it's far below what you expected then it's too late and you can't do anything about it then.
Just in case you are still considering this car you should know that at the listed price it would end up costing around $45,000 landed and complied in Australia (at the current rubbish exchange rate), and as noted in this thread already you should be able to get a good one for around $25,000 landed and complied give or take.
  • 2 months later...
J Spec..just wondering if history of repairs, would replacing a slightly dented left guard interfere with import..i hit a snow bank and got the guard replaced. It was minor but in japan they replace rather than fix.
fine as long as it's not structural.
and if you are bringing it back to aus as a personal import then it's not an issue at all. the 'no accident repair' problem relates specifically to SEVS compliance. since you live in japan just export the car after 12months of ownership as a personal import and you do not have to have the car complied.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
