This is how mine ended up.
used heatgun to mould it and foil backed foam for insulation from the motor
top is clear so i can see how dirty its getting, also dont need insulation there
same here, thats why i used a mixing bowl and a heatgun to shape where it goes in.
look closer at the second pic, see i put the afm right in there.
heres another one, with it installed
JBonDSS, I get heaps of air because I also have a CAI I made... you can check out that tutorial too wink.gif
Obvesouly there will always be air going to ur pod, if it was indeed air tight, your car qould seize up, so no matter how much you think your headlights seal off air, they never could completly....
In terms of air, you are assuming I have a spare Intercooler hole in there under the heatsheild? My car came as a non turbo....so I had no holes to begin with....I turboed it so We had to make one hole for the FMIC ... then for my CAI.. I had to make another 1... it is so easy...and I know about the legalities of this... but you cannot see inside the tinted perspex... and know one knows... biggrin.gif
Power wise I didn't really notice much difference with the heatsheild by itself... with the heatsheild AND a CAI... i have noticed a fair bit more torque at top end... which is fun tongue.gif you can tell it works well because you can get out of the car, whip open your bonnet and feel the heatsheild on the inner side and its cool.... while the rest of ur engine is at 80+
Adam
wow i am really intersted to see if there was a change on the dyno, i was under the impression that cai had no effect on turbo engines because as soon as it hits the compressor it heats up thats where the intercooler comes to play
it looks mint thought mate, you should make a few up and sell em off ;)
Yeh a CAI isn't going to make any difference to your power figure. Where they do help, is with heat soak. Do a few hot laps around a track and a good heatshield/CAI will help slow the heat soak of the system.
Ran my car on the dyno over and over on the weekend and no heatsoak issues, ran within 1hp of the power figure.... Airbox was warm but did the job!
  • 5 weeks later...
  • 8 months later...
^ looks neat with the aluminium.
How did you go about bending the aluminium? I want to make mine out of it, but i don't know how to bend it without an actual metal bender lol. Otherwise, i'd have to opt for the perspex one, which also doesn't look bad
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
