Hi all,
Tonight on my way home my car was cutting out over 4500rpm at full boost.My engine light would flash(PFC) and the car would cut power a couple of times.The hand controller had nothing out of the ordinary on it,but i did notice the AIRFLOW was at 5115v and im running a Z32,which is really high.
The car has never done this before.I am only running 16psi on a highflow.Could it be water going through the AFM(was pissing down)?
Its weird how the engine light flashes but no knock or high inj duty.And why all of a sudden am i getting high volt with the Z32?
Im stumped.
https://www.sau.com.au/forums/topic/208225-r33-cutting-out-over-4500rpm/
Bingo.
AFM gets wet. and it will cut out. Mine does this ALL the time.
There is nothing wrong with your AFM, its just when it gets wet it sends a high voltage to the ECU and the ECU cuts out the engine.
It feels like your head is going to go through the windscreen its such a harsh cut.
Mine does this all the time, and to be honest i never fixed it because once i was commin round a corner and no one was in sight, went to bring it onto boost to drift the corner, and bang.. CUT. 2 seconds later highway patroll comes around the corner... he woulda seen me full broadside.
:turned: if my AFM cuts out then i shouldnt be hitting boost because i will be all over the road anyway!!
Ah nice,thats what i was thinking.Ill go for a bit of a drive in it later to see if thats the case.Which i hope it is.
I was freaking out the first time it did it.I would drive normally everything was fine.Give it a boot and it would cut a few times and the engine light would flash.
I had my mate staring at the HC for about 20mins lol
LOL another thing to note.
Even if you park the car and drive it the next day and its not raining, it can take up to 30mins to a hour to clear up.
I deal with this problem EVERY time it rains, sometimes on the freeway when going up a hill it will cut on really low load and i have to chug up the hill because it keeps cutting out.. but this only happened a few times and it was really comming down very hard.
Your AFM / engine is fine, AFM's just dont like water, they are a hot wire remember ?
Maybe you shouldnt. Maybe you should stop spinning your wheels in the wet to impress your mates.
You drive a Skyline not a commondore! :turned:
Damn AFMs.Maybe i should sell the PFC and get a EV11V2 :)
the reason your air flow meter does this is because inside in between the mesh screen is a heat resistive wire which changes its voltage as it gets cooled by the passing air, so water will make the resistance across the wire and bingo hope that helped explain it
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
