Yeah I think that would be the next best thing to try if theres still valve train noise... as sticky lifters are fairly common. Personally I'd go with something like Nulon Lifter-Free if it was me but its up to you...
Goodluck mate.
  • Replies 43
could it be the ecu ?? some of the wires maybe ??
Doubt it. If the hoses to the inlet are blocked, one is the crankcase breather, so needs to be venting. Didnt you just put this motor in? Its definately lifters and not an ex manifold leak, they can sound very similar. Could try a compression test, as one of the valves could be sticky. I would be careful flushing the oil too much, unless you know that the turbo is fairly new.
crank case?? the cam covers have a breather if thats what ya mean i did just put this motor in yer it deffinaty lifters
it idles like a dog ??
Wait, you said your Oil pressure is 3/4 when idling hot?
That doesnt sound like a spun bearing...the pressure is way too high when hot. There must be something blocking the flow somewhere. Im guessing you can't see oil being thrown around when you take the filler cap off??
There's some galleries behind the oil cooler, and to the head that could possibly be blocked. It could be worth trying the oil flush next.
Basically I'd try to eliminate everything you can before tearing the motor apart.
ok this is the problem i came across and still no fix
i had a oil relocation kit on with a cooler and thermostat the thermostat wasnt opening causeing the oil to build up and no pump thru right so i have taken it off but left the relocation kit of the filter on so no more cooler
the pressure went down to a decent spot i also changed the oil filter
i then took all the lifetrs out i have two sets out of 48 24 were rooted so i cleaned them make sure they all work and then primeed them so when i put them in they would be full
put it all back together and the noise still happens straight up so its the tapping between the lifters and th valves
i brought this motor of a sau memeber ** not happy **
the head has being acid dipped cleaned and put back on the pistons in the motor were fine
im lost i need some help im selling the car the fella that is buying knows about the problem and i dont wnat a quick fix i want to give him the car in good condition
i have lined up a head that is in good condition but i dont wanna buy it and it not solves the problem
there is motor getting to the head on one side but only under load it use to flick oil out when i took the cap of now its got me stumpped
oil is also getton to the first part where the cam get bolted down at the front ofthe head yesterday i spent 9am till 6pm trying with no success im about to burn it anyone
can anyone help me
I gather you have never bled/primed hydraulic lifters then.
They ALWAYS tick and sound like crap until you take the car for a reasonable drive.
Well mine have and they have been done 3 times troubleshooting shit springs.
i have done them beofre i took them for a fair drive aswell i have lost power and im guessing this is because the valves arent opening fully
could it be from the springs
im up shit creek without a paddle
i have changed oil to the one they recommend i could get my other motor running good with 300rwkw but not this stock one
this is not a small tick aither it like the loudest disel car you have ever heard
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
