  • Replies 70
yeh seen your car fueling up at shell mate. Your right not too many have chosen the LED rear lights in town, chris's silver SII does have them though.
You wanted a sunroom that bad hey? everyone ive spoken to who has ever owned one never wanted another one again lol
Hmm never seen that one before. Looks nice man. I like that front bar. If you got nothing else to do, come down to the beach this sunday. Leaving from Northside BP at 1:30pm (meeting at 1pm, leaving by 1:30)
Factory sunroofs aren't normally a problem, its the ones that get put in that are normally the problem. Changes the atmosphere sorta when your driving, i like it opened when it rains BUT the glass is still closed. Chris has the Altezza lights with the LED lamps in them, i never seen them on a car b4 but everyone that talks tail lights on this sight seems to say LED ones are alright, the Altezzas are shit...I seen them on and i think they look pretty sexy. Put the cars sidee by side and you'll tell the difference.
As for going to the beach, i normally love to but, 20mins of driving and its starts squeaking really bad, like you can hear it over music, Control arm bushes rubbing.
heres one of mine, although i dont get on here much
Hey mate where abouts did you take that pic? Was it just after Rosslyn bay turnoff, up through the hills at that beach on the left with that real sandy track? If so, did you have much troubles getting in there? I haven't seen what its like for a couple years but I want to get some nice photos somewhere and that looks like a great spot.
my 32 gtst *new to gladstone*
Hey mate, have seen your 32 in gladdy a couple of times. Looks pretty neat, will have to have a closer look one day. I own a yellow 32gtr with white wheels and a maroon 33 gtst but i wont be in that for a while. So yeah might catch up with ya one day.
Cale
nah, i dunno the name of the spot, but its in emu park, pritty common and easy as for low cars
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
