# I have a standard gtir intercooler that i no longer need, im asking $250 for it ,its in excellent condition.
#the boost controller is a fueltronics boost controller, it has dual fixed boost settings and a dial to increase the boost. It also can control extra injector's and comes with an adjustable blow off valve.
Im not sure what model it is , but i payed $600 about 2 yrs ago and it was current working in a STI ,and never used since. willing to let it go for $400
