Hey ACT gang,
I've just ordered one of JustJaps turboback exhausts which should arrive in a couple of days.
I just have a question about the removal of the standard dump pipe etc.
- What is the general process for getting at the dump pipe? I assume you have to remove all the heatshields around the turbo.
- Is there anything I should becareful of in that area when removing the dump? I'll be reusing the o2 sensor, so i'll have that off already.
I realise that the JustJap exhaust might be a bit loud, but at the moment, my Kakimoto catback just doesn't cut it for me.
Edited by sfrizza
https://www.sau.com.au/forums/topic/208854-r33-exhaust-removal/
haha, good luck with the exhaust sensor and the O2 sensor if they have never been removed. I had to pay a workshop to remove them they were so ridiculously tight.
I took everything from the cat back off in one go then the dump and front together. Heat shields off first from memory then the 6 bolts attached to the dump (2 from bottom, 3 from top and 1 from either side) Watch out though, they are very brittle, would recommend replacing them when you put on the new exhaust.
What kind of exhaust btw?
Thanks for the info Baconer,
The exhaust currently on is a Kakimoto catback, the exhaust coming is a JustJap Hyperflow. I know its going to be loud (possibly overly loud), but this is easily changed by going to a classy oval muffler instead of a cannon. I need to get my burble, the Kakimoto is very quiet (nearly stock sounding).
So far i've removed the heat shield and have the dump soaking in WD40, which i'll also resoak tomorrow night.
Does any one know the thread depth, pitch and size of the bolts going into the turbo? I will try to pick some up but if i can't find any, i may run the risk...
I got no fkin idea bout the details on a GTST, but multiple applications of WD40, or what eva penetrator your using is the first thing. As Alex said, the fact the gears been heat cycled so often can make it a bitch... *cough shuffle* nothing like a GTR's dumps though... :cool: I almost stabbed a house mate over that.. jk.. kinda.
sfrizza... are you ReACT sfrizza by any chance?
Always wondered... ain't sfrizza's those extra long roiling papers? :);)
Yes, REACT sfrizza is me, one and same.... What's your username?
I could only imagine the dumps on a GTR... However, after taking a closer look at the dump, its near identical to the WRX dump on just on the opposite side and one more bolt. I'll keep applying the WD40 to soak into it thats for sure!
forgot about the wd40, i used about 3/4 of a can of that stuff haha.
And it didnt help? It was that last 1/4 you shoulda used! :cool:
Oh, no real OzRotary fame, just a JSR / RICE RACING / 13B BP TT / Toms silver arrow groupie :);)
I thought maybe with teh name, you prefere the longer papers... canberra style hahaha
Haha, no longer papers here..
Lol, well aren't you just the groupie now GeeTR! :cool: - Haven't seen RiceSP online in ages.............
Baconer, so far i've soaked the studs twice tonight about 1/4 to 1/2 a can of WD40... I'll do another two tomorrow night and see how we go. Hopefully the exhaust actually turns up tomorrow, I have no idea whether its been even shipped out yet... Bl**dy hope it has!!!
haha should be enough, i soaked mine, waited 20 mins then another soaking, 1 hour later they came off fairly easily. Are you doing this on the ground or in a workshop?
Also once you get the cat-back sections off make sure you rev the car for shits and giggles :cheers:
Also once you get the cat-back sections off make sure you rev the car for shits and giggles :)
Hhahaha well i smoked out all of Monaro Hwy this morning because of the WD40 soaking on the turbo exhaust housing / dump flange.... OOPS!
If you only left yours for an hour, hopefully I should be right then. Here's praying I don't snap any bolts..
As for doing it on the ground or in a workshop... I wish i had the luxury, i've already done 10 subaru liberty gearboxes on the ground, no point in stopping just for an exhaust..
Oh and if i get the catback section off first and its still not too late, bloody oath I'll give it a quick squirt...
Well I got her all done Thursday night. Its an extremely well built exhaust, the quality of the welds is very very good.
As for the sound... it sounds awesome! I have my RB burble back (it was bad having my N/A R31 sounding louder than my R33)...
All the bolts came off with ease. Putting the dump back on could have been better, the 2 middle bolts on the 6 bolt turbo flange didn't want to tighten all the way up (potentially). I had to much fear of snapping them so i didn't push my luck. Having said that, it isn't leaking at all :laugh:
Overall, very happy :down:
I have done this numerous times its a fiddly job but not to hard, soak all nuts and bolts in penetrate so as not to snap any while getting them off. You will find that some of the turbo nuts are more then likely loose any ways.
I was worried that the dump was going to be the hardest to remove, but it turns out that the mid section to back section was the hardest to do... Trying to get the exhaust in the hangers correctly at the same time as doing up the 4 bolt flange on the JJR pipe was just plain annoying... Needed a second set of hands to hold it all steady! But got there in the end.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
